Question about Sony gdm20d11 Monitor
Hi experts Hello boys, welI have a monitor sony model gdm20d11 for some years you that it is one of the best of their time but it is no longer very compatible with the new technologies me tranaj? with the very little time in a silicon graphic station but then I come to windows and it no longer served me and there is the problem here; I try to connect it to a PC and after making him the adaptations that recommend in this web and it didn't make anything it was same I have already proven several things I even made an investor of polarity and anything continues without working.The first help would consist in that somebody gave me a diagram of repairs of this since model I have not gotten it in any side of the web and the other one is that somebody explained to me in case you cannot use as monitor if I can use it (changing it the circuit of course) as tv monitor and that to make with twice as much since focus the circuits of TV come with a single connector.I donĀ“t know if you understand my English I wait that if, I am Cuban and they imagined the works that we happen for here for everything. I would thank them any help that you can offer me thank you salvatore
  • 77 Answers
Sounds like a conergence circuit failure, probably a couple of AMPs and a few discreet components. Probably 250-300 repair
Posted on Apr 21, 2007
  • 65 Answers
SOURCE: I Need the Circuit Diagram of KP-EF61 Sony Projection TV
Posted on Jul 13, 2007
  • 5138 Answers
SOURCE: Sony KV-35v35 no power
Bad Picture tube,and Flyback transfomer, shorted hori output.
Posted on Dec 12, 2008
  • 5660 Answers
SOURCE: Hello Sony RB30 w/ sdm-hx93 monitor. Approx. 7
Blond and Baffled, (CD), it's okay, I believe you have a common problem.
The computer sends a video signal to the monitor. The monitor is working fine. Hence - No Signal.
Monitor doesn't receive a video signal within a certain specified amount of time, it goes to a Power Save feature.
Just enough power is used, to keep certain components inside the monitor at a ready state. (When it gets a signal from the computer, the monitor turns back on)
The problem is the computer.
Most of the computers that come to my shop have failed because the inside of the computer, and it's power supply have never been cleaned, or VERY rarely.
[Plus one more problem, stated at the end of this solution]
It's understandable, as a computer repair shop charges a slightly hefty price to do this, (Not myself),
and it looks like a daunting task to most computer users.
It isn't.
The computer is unplugged from power, computer case is opened, and a can of compressed air for computers, is used to spray out the inside of the computer.
(Power supply also)
As dirt, dust, hair, carpet deodorizer, (And other material foreign to the inside of a computer), build up inside the computer, this is what transpires:
A) The cooling fan, and heatsink for the Processor, become clogged with the above mentioned foreign material.
(This is an example of an average Fan and Heatsink,
You can click on the images in the different views, to enlarge them)
In the link above the item that has many fins on it, is the Heatsink. The Heatsink sits under the fan.
The Heatsink functions like a radiator. The fins draw heat away from the Processor. (Processor not shown. The Heatsink is mounted to the top of Processor's case)
The fan draws air through those fins, which in turn draws the heat away from the Processor.
When the area in-between the fins is clogged with foreign material, plus the fan's blades, the cooling capacity drops tremendously.
This in turn allows the Processor to heat up.
The Processor has a certain thermal limit, and turns off when it becomes too hot.
It is a Fail Safe feature that is built-in. Keeps the Processor from burning up.
No processor running, no computer. Hence a No Signal to the monitor.
Solution 1, is to buy a can of compressed air for computers, unplug the computer from power, open the computer case, and clean the inside of the computer. (Also the power supply)
Should you like directions in how to do this properly, and if you need advice of how to open your computer case, please state so in a comment. (Believe top right of your page)
B) There is one more thing that transpires on a large percentage.
The Power Supply overheats also.
When the cooling fan of the Power Supply becomes caked with the above foreign material, it heats up. As the power supply heats up, tries to put out more power.
Heat = Wasted Energy
Also, there are Heatsinks inside the power supply that become clogged)
Eventually, the power supply components inside the power supply, fail.
Solution 2 is to replace the power supply.
If Solution 1 does not fix the problem, then I advise it's time to try Solution 2.
Should you need guidance to do this task, please reply in a comment.
(Tip: Once you rate a solution, you can no longer post a comment)
This link, states the specifications of the Sony Vaio RB30 Desktop PC,
Posted on Jan 08, 2010
  • 1138 Answers
SOURCE: My sony monitor flat LCD HS74P went black and heated up
Its easy to repair. Some parts that needs replacement are the blown and bulge capacitor in the power supply section on the monitor. They are the very first to be affected when something goes wrong. The others where the inverter transformer and the inverter light. Very cheap to repair, the labor is the one that cost that much. Bring it to a nearer technician in your area and it will be repair in no time
Posted on Jul 09, 2010
I want to download manual for gpr250 2 big boy
Hi, Trevor sorry no service manual the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 sometimes more and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, then there is eBay where you may be able to find what you need at a very high price because of its age and rarity. Most of the "FREE" manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the blue links below. Good luck and have a wonderful day.
2015 Big Boy GPR250RS Overview
Big boy scooters spares
1 500 Big Boy GPR Parts For Sale
big boy xtg 250 owners manual
Feb 18, 2017 | Big Motorcycles
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
Hello, I'm a Brazilian SONY consumer, but I live in USA for many years and got a HomeTeather model STR-K740P some time ago. I took this unit to Brazil and gave to my mother. After some time the central...
You have to be guided by Sony's information. Phone them and ask them again, they are the experts in their own products. Buy it from Sony and then you can send it back if it looks wrong.
Mar 08, 2017 | Sony Audio Players & Recorders
Hi, i have a sony vaio laptop with no display, have tried a external monitor still no display, have lights, fans,CDRW runs any idea's ?
Please check your video card. I gues you have a defective one. If the video card is a problem, change it with same type and model.
Best regards,
Oct 08, 2009 | Sony MBX-49 ASSY Motherboard
Hi, I am looking for better battery for my sony
Hello there if you get a battery make sure that it is
a Lithium ion type battery they give the best run time
and it takes less time to charge the life time is also longer
best regards michael
Sep 23, 2009 | Sony Vaio VGN-NR110E/S Notebook
GDM20D11 repair manual
Utilize OLM to PST Converter programming which can repair and change over MAC Outlook Emails or OLM Files into Outlook PST Formatted documents with no errors.It additionally repairs ruined and harmed OLM records and make them open as PST which effortlessly available through MS Outlook.The programming change over all messages thing, for example, email messages, contacts, errands, diaries, notes, hyperlinks, logbooks, email connections and etc.It bolsters all refresh all variant of MS Outlook 97, 98, 2000, 2003, 2007, 2010, 2013 and 2018
Jan 04, 2018 | Sony gdm20d11 Monitor
Compaq 1501 15" LCD Monitor ( Blinking Display)
Hi BOY! :P
Check if there is anything wrong with the video input cable to the monitor. If not then you should move ahead with the replacement of the ceramic fuses. There should be around 6 of them in most monitors i have fixed. They will look like this(click here) They should cost you around 1$ each.
If none of these work then your monitor's inverter board is probably screwed and needs to be replaced. should cost you around 30-60$.
Aug 30, 2008 | HP Compaq 1501 15" LCD Monitor
Dell LCD monitor suddenly loses power
Five years is a long time for an LCD panel. You definetly got your money's worth.
But, if your trouble shooing has led you to this conclusion I can also only conclude that the power driver inside your panel just gave up the ghost.
However, try giving Dell a call, for what's thats worth and see what they have to say.
You might also want to ask this expert "Robotek" what he may think as he is a board troubleshooter and could give you an answer if one is there.
Type this or copy and paste into your browser's address bar:
And then click on the Ask Me button under his picture.
Best regards,
Jun 21, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Hello guys :
speak to sony, they will fix it
May 07, 2008 | Sony Playstation 3 (PS3) Console
this side is Ajay
I am exel user for more than 1 year . i have got the solution of this problem
we can apply Index & Match function to solving this problem
Best Regards,
Ajay Kumar
(MIS Exceutive)
Nov 29, 2007 | Sony GS Series Model 520 (White) 21 in.CRT...
Sony gdm20d11 Monitor Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
