Question about Fisher and Paykel Washing Machines
I have a Fisher and Paykel IW811 Intuitive Eco washing machine on which I have recently replaced the pump motor and motor control board. I have reset the size for 650mm.
I am getting no error codes coming up, but when I switch the machine off, the "Stained" lights all turn on and flash (all green and orange LEDs - less to more, turn on together and flash). Can anyone assist with a possible cause and solution? Thanks
    Habit-Forming:
  • Fisher and P... Expert
  • 195 Answers
Switch power off at wall & unplug machine for a couple of minutes. Plug it back in and power on. See if it resets it, If not then you may have a faulty main board or it has been damaged somehow during fitting.
Posted on Jan 12, 2017
SOURCE:
SOURCE: Error: 0xf0af8005
Hi ,
This error relates to hardware problem.. i never faced this problem but heard lot of users talking about it .. as per HP techies it takes close to 150$ to recitify the problem which is almost a cost of new printer...
Would recoment to contact hardware manufacturer if the product is still under warranty....
Please let me know if this post was usefull..
Thanks...robosoft..
Posted on Dec 17, 2007
SOURCE: error code 5010
Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
Sooooo irritating!!!!!
Anyone know what to do?
I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
Posted on Aug 21, 2008
SOURCE: Canon Photo Printer iP4500
buy new printer
Posted on Sep 05, 2008
  • 990 Answers
SOURCE: Sharp AR-405 error code F1-15
Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
Posted on Feb 16, 2009
komguy
  • 2306 Answers
SOURCE: cannon ip3000. light flashing green/orange and
6A00 means the purge unit is stuck, it's the unit on the right that cleans the printhead. If you can see on the right, look for any paper scraps or things that don't belong. Otherwise it's a shop repair.
Posted on Aug 28, 2009
Pumps out instead of recirculating
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel washer keeps saying cutoff restart
The power supply is faulty in the motor controller.
Replace motor controller with new/Reconditioned board.
Apr 25, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
How to replace a power module in a washing machine
Motor controller has faulty power supply.
You need to get a new/recondition motor controller board.
Apr 06, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine (F&P) model no: 12502 will
likely fault is electroic motor control board,in some models eg: gw709 if the pump is open circut the motor controlwont light up check this too
May 15, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel intuitive code 37
My machine is actually an IW811. But what happened was I checked motor see if it was spinning & confirm it was. But realised instead of pumping water out, it was going back into bowl, went straight to diverter valve, found control solenoid was burnt, was very hot to touch, even though hasn't been operating, only with main power point on. Suspect motor control board faulty as well. Replaced both parts & was fine after that. New contrl board has been upgraded & came with listings of all codes, explaining every code in detail. Specs to test switch, motor & solenoid resistances. But thanks to you guys for pointing me in the right direction, with what code 37 means in the begining.
Nov 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Intuitive Eco Washing Machine
The drain pump is overheating. I suggest you do not try to use the machine until you replace the pump unit, failure to stop using the machine will result in the pump short circuiting and destroying the main control board!. Please go buy a new pump and fit it.
Sep 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
