Question about Kenmore 63142 / 63144 Top Freezer Refrigerator
The defrost fan continues to run,cleaned coils yesterday been over 24 hrs. it isn't cooling like it was. The freezer is still frozen and the bottom is still cooling but the freezer isnt freezing like it should (ice feels wet). The unit is about 8 or 9 yrs old. Freezer on top. Thanks for your time
  • 83 Answers
Change the defrost timer !! swampratt200
Posted on Jul 21, 2009
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
Freezer not cooling properly
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Top half of upright freezer is warm
Hello Karen;
My name is Peter. I am a retired field service refrigeration technician.
The top half of your freezer is warm because your cooling (evaporator) coil is on the bottom.
With your unit there are generally two cooling problems:
1.) Frozen Drain - You freezer will go through a defrost cycle every 8-10 hours. When this occurs, everything shuts down with the exception of your lights. Your defrost heater turns on for about 20-30 minutes, defrost you cooling coil and them turns your unit back on.
Most common, is that you have a frozen drain. If you have a frozen drain, when your unit goes through the defrost cycle, if your drain is plugged then the condensate builds up on your cooling coil and restricts the air flow. Use a hair dryer and melt the ice.
2.) Freezer fan motor is bad - Your freezer fan motor may be bad. This is easily replaced.
Ok, Lets get it done. I have faith in you.
a.) Unplug your unit.
b.) With a screw driver remove the 6 screws holding the bottom cover. You control may be in the way.
c.) I know you can do this. Remove the back cover. Is you cooling coil blocked with Ice? Defrost with a hair dryer. Do not use metal tools, you may damage the cooling coil.
b.) After defrost, Is you cooling fan running. You can do this as well. There are only two contacts to remove and a ground wire. If it is not running purchase a new one.
I have faith in you Karen. Call me and I will walk you through this.
443-306-1362, Glen Burnie, Maryland, USA
Dec 29, 2014 | Freezers
My electrolux ERN2820 is not working the light is on the moter is running but the freezer is defrosting and the fridge has lost it temp
Have you cleaned out the coils lately? Sometimes they become full with dust and will not cool properly. If the coils are clean, check that the fan is running. If the fan is running, maybe the compressor isn't. If the compressor is running and all else looks good it is probably low on freon.
Feb 03, 2012 | Electrolux ERN2820 Bottom Freezer...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Refrigerator runs, not cooling
Sounds like you have a defrost problem. the easy way to check this is to turn the unit off for 24 hours doors open.
Then turn back on and if it starts cooling ok it is a defrost issue
Jun 06, 2017 | Kenmore Refrigerators
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
My 3 year old bottom frezer samsung fridge stoped defrosting automatically.Ice builds up in vents till stops cooling.After unpluging and defrosting for 24 hrs manually,works good for 2-3mnths.Cant find...
3 things defrost heater, defrost timer or defrost limit thermostat.
You can pull the cover inside the freezer exposing the evaporator coils,
look for the defrost heater at the bottom of the coils. Test for continuity.
Find the defrost limit thermostat, a 2" metal disc attached to the evap coil usually on the side towards the top has two wires going in and will have continuity only when it is cold. If those are good probably the defrost timer.
Nov 04, 2009 | Samsung Refrigerators
Refrigerator/freezer not cooling evenly top to bottom
good then go ahead and ohm out the sensor and the relays to see if the resistance is close to the normat. 70 degrees is roughly 1000 ohms. relay you are lookling for continuity or open. then you can also ohm the fan motor too. let me know what you find;.that will determin whts bad and whats good
Dec 25, 2008 | Kenmore Refrigerators
Kenmore 63142 / 63144 Top Freezer Refrigerator Logo
119 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
