Question about LG LRBC22544 Bottom Freezer Refrigerator
LG LSC27926 side by side refrigerator-- Error Code FF
I have the same problem. Three times in 18 months. I do not want this refrig any longer. Since this problem is so numerous I am thinking of Finding a class action lawyer to try to help us against LG. I can be reached at martenhirsch@gmail.com if interested in pursuing.
    Master:
  • 363 Answers
This website can help you www.rsgoldfast.com
They serve good high efficiency, safe and convenient transaction, you can go to experience
The price is certainly the cheapest
There is also often very affordable activity
Posted on Dec 27, 2016
    Champion:
  • 363 Answers
FF STANDS FOR FREEZER FAN
Posted on Jul 21, 2009
My lg fridge is giving me an error code of FF what is this mean
Your LG refrig is in Demo Mode.
1.- disconnect power supply and reconnect
If the error continue
1.- Open the door of refrig.
2.- Press button "Refrigerat" while press "Ice P" button 15 seconds
If the error continue try again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | LG Microwave Ovens
Freezer temp ER Refrigerator temp FF
When the refrig is running, the fan in the freezer section should be blowing air. Check for frost build up preventing the fan blade from turning.
Mar 06, 2011 | LG LRSC26920TT Side by Side Refrigerator
I have an LG SXS side by side refrigerator that will not dispense water. The display shows FR & FF. If the supply is switched off and then back on again the display resets for a period of time. Over...
Er FF - Freezer Fan Error - This can be caused byfrost accumulationon or around the freezer fan. Unplug the unit for 3-4 hoursto allowthis to melt off. If error code persists, call Customer Service.
Jan 20, 2011 | LG LSC26905TT Side by Side Refrigerator
Trouble with model LFC25760ST inside display refrig registering Err and freezer FF and things are not cold
That is a freezer fan motor error, the freezer fan is no longer running. Check the freezer fan for a loose connection, if everything checks out ok there you probably need to replace freezer fan.
Oct 07, 2010 | LG Refrigerators
I have a Kenmore Refr. Model # 795.77563600 has a Error FF
The FF error code indicates that the freezer fan motor is defective.
You need a new main control board and evaporator fan motor.
The fridge is made by LG, but rebranded as Kenmore by Sears. First 3 digits is the tell. You can call Sears for parts.
LG refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Error Code ER FF
I had the same problem. I can tell you that simply unplugging the fridge and letting it defrost isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it started working again. Then two days ago I got the error again. This time I decided to get inside there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out of it to get that back panel off. This includes the ice maker and the rails that the drawers slide on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my freezer one is a white screw high in the center and one was a gold screw in the little panel that the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm pull, but take care not to yank it too far... it's still connected by wires back there. When I pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours as it gets back to being cold.
I'd say you need moderate tinkering skill to do this. If you only own one screwdriver and you never use it you should probably call someone.
Hope this helps!
Oct 18, 2006 | LG LRBC22544 Bottom Freezer Refrigerator
LG LRBC22544 Bottom Freezer Refrigerator Logo
312 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
