Question about HP Photosmart C5280 Printer
Black line on page vertical on receivers end
When I send out faxes, they transmit with a long vertical black line on them. I have checked to make sure no piece of paper is hung up in there. It is mostly to the left of the page. Top to bottom about 1/4" in width.
    President:
  • 787 Answers
May be you have, a trash or something on the scanner glass or scanner section lamp.Try to disassembly and clean the lamp.
Posted on Sep 28, 2009
Brother MFC-9840 poor print quality.
Hello you can try and fix your problem using the steps suggested below. You may need to clean the corona wire
1. Lookat the corona wire on each toner cartridge. If a corona wire is dirty that maybe the reason that you receive black lines on the pages.Do you have trouble when you receive a fax? If that is the problem look what is cousing it below:
1 Ifyou receive black lines while receiving a fax, the cause of that problem may bedirt in the fax which is sending you the information to you. Advice your senderto clean its fax or to replace the toner cartridge with new.
I hope this can be of any help to you.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
Black vertical lines on transmitted faxes.
Just go to menu and then in tools...run alignment and clean them....
Jun 29, 2010 | HP 1040 Plain Paper Inkjet Fax
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Transmitted pages are too dark, practically unreadable :
I suspect your scanner unit is going bad or it is extremely dirty.
Making a copy gets same result as when you send.
Nov 01, 2008 | Brother FAX-8360P Plain Paper Laser
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Even vertical lines on fax/copy
TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
Sep 16, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
HP Photosmart C5280 Printer Logo
108 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
