Question about Coleman Mach 15 Air Conditioner
Im at an rv park, approximately 90 degees in the sun, air was cool for about 2 hours, fan continued to run but no cold air. When I change the thermostat I can hear it click but nothing changes.
  • Coleman Master
  • 6,674 Answers
Take air filter off , look up inside & see if coils freezing/frosting up when starts to blow warm air.
Is this a new unit, and has it always done that or just recently?
Posted on Jul 22, 2009
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
My car A/C blows hot air for about 10 minutes after being parked under the sun for hours.
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Apr 29, 2012 | Chevrolet Malibu Cars & Trucks
My rv compressor will run for about 5 to 10 min and then the compressor will shut off "fan will continue to run because the temp is not cool enough to shut off" and then the compressor will try...
This is most likey due to a low voltage condition within the site 30 amp hookups are not enough esp if there are a lot of other units in the park. got a generator?
Jul 31, 2011 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
How cold should it be in rv with two low orofile
Most AC units only change temperature approximately 20 degrees F from ambient.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
2000 roof-top Brisk-Air
I think you have a high pressure cutoff cycling the compressor on and off. Clean the filter inside the unit. Then with a hose clean out the foil condenser filter on top of the camper. Also you may need to buy a coil comb and comb out bent or damaged areas of the condenser coil on the unit that is above the roof of the camper.
Jun 09, 2008 | Dometic Rooftop RV Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach 15 Air Conditioner Logo
236 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
