Question about Frigidaire FRS26H5AS Side by Side Refrigerator
I have ice build up at the bottom of my frigidare freezer compart
It builds up in about three days and then starts to leak out. It is not coming from the ice maker because I turned the water supply off and it still did it. Please help. Thanks, Seth
  • Frigidaire Master
  • 4,654 Answers
Sounds like the defrost condensate drain behind the rear panel inside the freezer is frozen over. You will need to unplug the refrigerator and remove the panel. Defrost with a hair dryer and pour warm water into the tray that collects the defrost condensate and takes it down to a pan below your refrigerator to be heated and put back into the air inside your home. If for some reason it is not ice blocking the opening you will need to use a wet and dry vacuum cleaner to try to dislodge whatever is blocking the flow. Let me know what you find, Thanks, Sea Breeze
Posted on Jul 21, 2009
  • 33 Answers
Clean the coils under the fridge and drain pan
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Leaking water from the bottom on the freezer side. It's a side by side refrigerator and is set up for water/ice on the front left(freezer) side but this has been disconnected and is not in use. Water...
check this website repairclinic.com they are talking about a clogged drain plug for the defrost cycle. seems we have exactly the same situation. see if this helps
Sep 24, 2009 | Kenmore Refrigerators
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Bottom of feezer building up ice and leaking
This just happened to me. take the panel off inside of freezer and you will see the evaporator fan this could be the problem. test it before placing.Also there is a thermostat in there too. A little round device that will kick the fan on when the temp is around 34. Both parts together are about 90 bucks if you get them yourself online. About 170. through a dealer.
Apr 10, 2009 | Refrigerators
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice at the bottom of the freezer
bottom of rezzer compartment is supposed to be frozen( depending on timeof cycle) i wouldnt point to a defrost problem unitil the ice build up is hindering refigeration, its quite possible that thte defrost drain has just frozen itself over, and needs to be cleared to allow defrost water to go into the drip pan under unit
May 02, 2008 | Maytag MSD2756GES Side by Side...
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
297 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
