Question about Kenmore 62802 Electric Dryer
Dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top off, took the vent out of the back and got as much of the lint I could out of those areas. Some of the lint was black as if it had been burnt. In front of the dryer drum where the inner lint trap is located (once you open the door) I could reach down to the bottom of the dryer and pull out more lint, alot more lint! So today I tried the dryer again and after about 15 minutes on high setting it got hot again and started working fine. Or so I thought..... An hour or so later I felt the top again and had the same problem...HOT! Why is the dryer staying hot when it's not even on???!!!
    President:
  • 1,714 Answers
More than likely, the motor centrifugal switch is stuck. You should be able to turn off the element with the timer control switch. If the timer switch is on and the dryer is not running, the element should be off, unless the motor contact is stuck closed. You will have to get to the motor and 'un stick' the contact.Its a bit tricky, you may need help.
Posted on Jul 21, 2009
reg501
  • 413 Answers
SOURCE: Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Posted on Jun 26, 2008
SOURCE: clothes not drying
clean vents, including exhaust vent
Posted on Dec 16, 2008
SOURCE: We have modelPYE2300AYW it quit drying. The lint
it has two different high limit switches that need to be replaced . one in the front and one in the rear. this happened to mine and it cost about $20.00 to fix
Posted on Oct 31, 2009
  • 3600 Answers
SOURCE: will not dry clothes.
Your heater element may be burnt or you may have to many bends in the vent pipe. also try a smaller load if you still have trouble let me know and I can give you a diagram and tell you things to check in order. You will need a volt meter to do the test and understand the dangers of operating voltage. Also Just for the heck of it try resetting you circuit Breaker for the dryer.
Posted on Jan 31, 2010
woodchuck789
  • 4070 Answers
SOURCE: Clothing getting caught on lint
Probably has extra space between drum because the front felt guides on the drum have worn. This can be accessed by removing the front panel.
Posted on Oct 05, 2010
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Dryer is heating but clothes are not drying.
Judging by the increasing moisture, your dryer vent is not venting the moisture to the outside. Check your vent pipe for blockages. I had a person a while back with a similar problem, and this person had a lint trap on the connection that went to the exterior of their house, so check that out as well.
May 08, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Kenmore Dryer doesn't shut off and doesnt' get hot
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 14, 2010 | Kenmore 73952 Gas Dryer
Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Sep 05, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Kenmore 62802 Electric Dryer Logo
235 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
