Question about Dell Latitude D600 Notebook
Dell D610 charging problem
I have 2 dell d610s. Unit one works great. Unit two has a problem. When I move the charger and the battery over to the unit two, it runs fine, but the battery will not charge. What is wrong with unit two?
  • pc guy Nov 20, 2007
    1. It will not run off the external AC charger when the battery is removed.
    2. It runs perfectly off just the battery.
    3. If you plug in the AC charger when the battery is there, the fact that the AC charger is plugged in does not show up in the task bar icon. It remains in battery only mode.
  • Marty55 Dec 23, 2007
    I also have two D610s and one will not charge the Battery. It runs with and without the battery installed. It will also run with the battery itself. It just wont charge the battery. What is the fix
    Scholar:
  • 181 Answers
Does it run without the battery installed? Also, will it run only off the battery? Isolate those two conditions, then we'll be able to narrow down the problem.
Good luck
Posted on Nov 20, 2007
  • jim walenciak
    jim walenciak Nov 20, 2007
    Well, since the rating is locked, I guess you aren't interested, or have already determined the problem. In case not, It would appear that the ac socket (the socket where the adapter plugs in to the laptop) has became unsoldered from the motherboard; this situation is repairable, although takes a steady hand, and requires the laptop be completely disassembled. MY shop could fix it if you were only in the area.
    Good luck and thanks for playing.
Will keeping the ac plug connected kill my battery on Dell latitude d610?
I will suggest you to use laptop after it is full charge by removing the charger . when ever you feel battery is down then you can plug in the charger and keep using it, and when ever you see battery is full then remove the charger.
I'll not suggest you keep plugged in the charger when you are done, this way it can effect your Battery. and yes your battery can die with in a year if you are not follwing the correct way to use it.
Aug 15, 2012 | Dell Latitude D610 Intel Pentium M 1.6GHz...
My dell latitude d610 ac power is work is properly but battrey is not charging plz tell me soulition.
If the D610 works when attached to the AC Power Cord, it is likely that your battery is not capable of taking a charge and needs to be replaced. I have 2 D610 Dell Latitudes and they are very good laptops.
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Dell Latitude D610 Notebook
Hi! My Dell D610 doesn't charge the battery. When I plug the charger without a batt, the system powers on but the batt doesn't get charged when attached. Help me solve this problem pls.
1. Install and update the system BIOS:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=LAT_PNT_PM_D610&os=WW1&osl=en&catid=&impid=
Note: Make sure that both the ac adapter and the battery are attached to the notebook. Follow on-screen instructions on how to flash the BIOS.
2. If Dell QuickSet is installed, press <Fn><F3> to display the QuickSet Battery Meter. The Battery Meter displays status, battery health, charge level, and charge completion time for the battery in your computer. If battery health says that the battery is degraded and needs replacement, then you may need to replace your battery.
Nov 12, 2010 | Dell Latitude D610 Notebook
Why wont my dell D610 charge i have changed the battery and charger
Hey!
If you are still encountering the problem charging your laptop's battery, it is possible that the port where you connect the adapter or the port for the battery is damaged. It will still receive power but it won't charge.
Best solution is to replace the motherboard. Just make sure you would get the exact same devices on a replacement board.
Hope this helps! :D
Sep 09, 2010 | Dell Latitude D610 Notebook
Dell Inspiron 6400 wont recognize new battery
Well often batteries from 3rd party manufacturer do not work in some laptops, see even the batteries have a "Chip" in them identifying them. Also sometimes these batteries are just no-good. or arrive flat, too flat to be charged up via the supplied charger. Anyway hopefully none of that applies and this will work. Now Turn PC OFF, put battery in unit. Now plug in wall unit, then plug into the PC, now leave the PC totally alone for at least 3 hours. Now the unit should work. Now how we tell where the problem lies is like this, Turn OFF, take out battery, now plug in the wall adapter, now the PC should work Fine like this. Now remove wall adapter, and insert the battery, the unit should go on this.. ONLY of course if charged. Now if when plugged in there are problems, it is more than likely, that indeed the battery is faulty, in some way.
These links below detail what steps to take to remedy any situation. The 2nd link is great.
http://www.dell.com/content/topics/global.aspx/batteries_sitelet/en/batteries_faq?c=us&l=en&cs=04
http://ftp1.us.dell.com/diags/R66243.htm
Mar 22, 2010 | Dell Inspiron 6400 Notebook
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
My Dell latitude d610 charging circuit not working on board
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Jul 31, 2009 | Dell Latitude D610 Notebook
Quick question re: Dell pocket DJ 5gb....
From what I have read, yes, it charges via USB.
May 19, 2008 | Dell Pocket DJ MP3 Player
Dell D610 Batteries don't charge when AC adater is plugged
this is usually a sign of a common problem with these laptops. Usually the power works but it will not power the batteries to charge them. If the power adapter is fine- you have a bad motherboard.
Nov 23, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
300 people viewed this question
Alun Cox
