Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Capresso E8 - Error 8 - My Capresso E8 is 4 yrs old and has had occassional Error 8s that have now become quite common. After powering off for an hour or more, it will clear. From what I can read, it sounds like an o-ring problem. Have seen directions on lubricating the rings on an S9, but they don't appear as accessible on the E8. Suggestions?
  • 1 more comment
  • steve953 Jul 21, 2009
    Thanks for the response - It's past that issue, I believe. While it often will arise when the brew unit is full of grounds, it is start to creep up in other situations as well, including mid-cleaning cycle. In daily use, it generally will make it through one cup/cycle ok, and if that is all I do at that time, I'm successful at the next brewing as well. However, if I do two cups/cycles in a row, it almost always is getting stuck on the second one. I'm imagining the rings getting swollen from the heat/water, making them less cooperative in the second cycle.
    Appreciate the first response, but I think the problem is beyond the grounds. I've had it occur even mid-cleaning cycle. If I make one cup at a time, it seems to function ok. If I make a second in succession, it invariably will bind up after the second and go to Error 8. I'm envisioning (correctly or incorrectly) the o-rings swelling or becoming less slippery from teh heat & water, causing them to bind on the second go-around.
    I appreciate micromatikal's response, but before aborting (or paying Capresso $250 for a repair job), I was hoping there was an o-ring solution for this unit, as I've seen posted for others.
  • 3,037 Answers
The problem is that the machine just gets clogged up and overheats a little. If you work on a coarse grind or clean it out each time that it happens the error should not show as much or at least you should get rid of it for the time being. Again basically the ground gum up the moving parts inside, and so it doesn't like the extra work and shuts off preventing any overheating and wrecking the machine. I hope this helps as there really isn't anything else that you can do to prevent the error from happening. I wish they would make stuff more like they used to.
Benjamin
Posted on Jul 21, 2009
    President:
  • 2,777 Answers
I had this same unit and it had the exact same problems you, Capresso just gave the advice to keep rebooting the unit, after a while it was so bad that it would only work for one shot and it would error out. Apparently there is nothing you can do for the unit and Capresso doesn't really support it, I ended up getting rid of it =(.
I know thats probably not the answer you wanted to hear but just wanted to let you know.
Thanks
Tim
    Genius:
  • 1,043 Answers
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffee grounds inside the brew unit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
How to fix error message 8
DISPLAY SHOWS MALFUNCTION 8 Solution: Turn off and unplug machine. Wait a minute. Turn machine on and wait until it stops making any noise. Now try to pull out the drawer. If this does not work, try the procedure again. If this does not work, call customer service
Regards Kat (please leave feedback, many thanks)
Aug 19, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso E8 keeps getting error code 8 over and over. I will clean, remove grounds etc, it will make a few espressos, then back to the error code. I can hear it struggling.
One of the problems that I see with these units is the Grinder setting. Sometimes the grinder is set too fine for Dark and Oily beans. This setting will ( can) clog up the brew screen after less than 10 cups are brewed. Also, running the cleaning tablets through to create a clean starting point may help you. Try turning the grinder to a slightly coarser setting and try that.
Sep 21, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Capresso jura S9 IMPRESA
hi did you ever fix this problem, i too have this - i know it is because of coffee sludge built up in the system but i want to know how to open the machine and give it a good clean - cant seem to work out how to do it though.
Apr 30, 2010 | Jura Capresso Impressa F9 Espresso Machine
Makes grinding noise then Malfunction 8
Jura Capresso E8 Makes a cup of espresso then makes a gear grinding sound and then throughs an Error * on the screen. Machine was repaired by Capresso a year ago.
Oct 27, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Rinse error
I'm not exactly sure what was going on as I tried again to push the rinse button possibly a little harder this time and now it is working fine.
Sep 26, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Mulfuction 8
for my E8 it meant block water flow - i had installed filter improperly. took it out, power down/up, error cleared.
Anyone located a service manual for Capresso's?
Jan 24, 2008 | Jura Capresso Impressa S90 Espresso...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
475 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
