Question about Canon imageRUNNER C3200 Color Printer
"warte..." on IRC2100 copier
When I use Option (Optionen) key for print or scan, Only "Warte"... is displayed and no thing after. Please I need help
  • digital_nige Jul 21, 2009
    Please, how to solve this problem?
  • tariq_masood Oct 10, 2009
    i have HP DesignJet 2000cp there is a code 050000 00180516 please help for this problem.
    Problem Solver:
  • 8 Answers
Its fooked
Posted on Jul 21, 2009
Canon irc2100
Sir, there doesn't seem to be an error code accounted for that reads E30.
Canon IRC 2100 Service Repair Manual
That is the link to the service repair manual which also has the error codes so you can diagnose what is going on although there doesn't seem to be an E30 code accounted for.
This is a more extended list of all of the error codes and once again there seems to be no E30. There are 9 pages of error codes if you'd like to look.
Error Codes Canon iRC2100 page 1
Perhaps a mistype?
Aug 30, 2014 | Canon iR 2016i Black and White Copier
I have canon copier ir c2100,i cant print becouse when ever i try printing it displays as out of paper but there is a lot of paper too what do i do
Try to put paper into the manual feed tray and let it print. I would check to see what you default tray is set to... It may be to the manual feed tray and make sure you have the correct paper size for your paper trays
May 16, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
Hello there i have a lanier copier model ld 160c color copier everthing work fine and functional acceipt i can not make full color copy, when i press the full color button then the display panel show up TO...
Hi, somehow the external key counter option for your copier got turned on. This option is typically used for coin-operated copiers such as those found in libraries. You can turn this option off by doing the following:
- Press the User Tools button - Select System Settings - Select Admin Tools - Select Key Counter Management - Choose Off, or de-select the full-color option if it is selected. - Exit out of User Tools
Now you should be able to copy normally!
Dec 02, 2010 | Lanier UNKNOWN
HP photosmart C4480 - 'scan to print' prints very small on A4?
You need to find the scan option on the printer and modify it.
Sep 02, 2009 | HP Photosmart C4480 All-In-One InkJet...
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Canon Irc2105 Colore Copyer Machin
E215 -The thermistor of the scanning lamp (fluorescent lamp) exceeds
a specific temperature, check your scan lamp
Apr 05, 2009 | Canon imageRUNNER C3200 Color Printer
Canon 6260 photocopier error E214
i have conon irc2100 i wanet this michine conect with computer plese your solution
Jan 05, 2009 | Canon imageRUNNER 210S Copier
Error response on hp psc 2355 AllinOne printer,scanner, copier
Issue The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, please let me know.
Thank you so much. I Remain
adonscott
HP TECH
Jun 18, 2008 | HP PSC 2355 All-In-One InkJet Printer
Tally T8106
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  • Power the printer on while holding down MENU/ENTER key
  • Release the key when the display shows "Utility Menu Clear FC. Roll"
  • If you have replaced the FC Roller then select this option by pressing MENU/ENTER key, if you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  • When one of these options is selected by pressing MENU/ENTER key, the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute" by pressing MENU/ENTER key again the display will change to "Execute"
  • Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear FC. Roll / belt CG"
  • Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jan 28, 2008 | Tally T8106 Laser Printer
Data Light comes on - boots up but stays on wait - please help!
Network printing was optional. The network connection is misleading; it is there for scanning. You may have to use it as a local printer and share it.
Dec 08, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER C3200 Color Printer Logo
115 people viewed this question
old marine
old marine
