Question about Samsung HL-P5063W 50" Rear Projection HDTV
The Samsung HL-P5063W lamp went out, leds showing. At about the same time we heard a buzzing sound we hadn't heard before. deep and variable. Question is: is it just a coincidence that both happened at same time? And, if the fan needs replacement is it something we can do ourselves?
  • 1 more comment
  • eq15 Jul 22, 2009
    Well There are some clarifications I need.
    1. It seems to me that the lamp did go eg the 3 leds lit up (and I have a new one coming tomorrow)
    2. Would there be a causal reason that the fan and the light failed simultaneously? Seems unlikely.
    3. The idea that the deep rasping sound is the power supply intrigues me since the connection seems causal -could a power supply "failure" or outage cause the lamp failure? In which case the lamp may still be ok? If I put in a new light without first curing the vibrations (supposedly from the ps) could the new lamp be damaged unwittingly?
    4. Would a failed power supply make the continued sound of vibrations any time I turn the set on?
    5. Can we some way quickly test whether the power supply is failed or failing?
    6. I would like to know with certainty if the noise is coming from the fan or the power supply
    Thanks
  • eq15 Jul 22, 2009
    I am uncertain if the cause of the lamp failure has something to do with either the power supply or the fan. The simultaneous failures seems less likely if it is the fan ie no causality. And there is still this low vibration if I turn the unit on. Fan problem? Power supply? How do I tell?
    How can I test to see if there is a power supply failure? and if there is, wouldn't it be unwise to put in a new lamp unit as it could be harmed by the damaged PS esp if you believe that the PS caused the first failure..
    I would like to solve this issue before getting an estimate or putting the new lamp in.
    How do I tell? Power supply or Fan failure - or neither?
    Tom
  • eq15 Jul 22, 2009
    Although there is no certainty as to which unit failed and the expert is not sure, I accept the solution proposed but would just like to know how to test the fan.
    Thanks
    President:
  • 2,777 Answers
Hello there, it is possible that it's just a fan on the unit that has died, and if so it may be replaceable by yourself. However it does sound like the lamp has actually failed, and possibly the power supply along with it (or maybe the power supply failed causing the lamp to go). Either way it is most likely much more serious than just a bad fan.
I would have someone give you a free estimate / evaluation locally if possible.
Here are the parts for that TV if you wanted to get an idea of the cost per part:
http://www.partstore.com/Model/Samsung/Samsung/HLP5063W.aspx
Posted on Jul 21, 2009
  • Tim Grayson
    Tim Grayson Jul 22, 2009
    That definitely sounds like a lamp, but like I said (and you mention here in a moment) it could also be the power supply.
    The fan could fail and the lamp could overheat thus causing it to short out / fail. It can happen.
    It could, chances are that it won't damage the lamp right away, if you plug in the new lamp, fire up it, and the lamp works but that pulsing sound is still there shut it down and inspect further, see question 6 here in a moment...
    Yes definitely
    Unfortunately not really, the way I test it when repairing is to just replace the part and see if the issue clears up...
    The best way to check this would be to unplug the fan (it should have a power connector of it's own) and fire up the unit. If it still pulses then you know it wasn't the fan, if it goes away then it was...
    Thanks
HL-P5063W Constant buzzing when on or off
The clue is you hear it with the set off, most likely a transformer or coil in the standby power supply, not unheard of (no pun) for this type of part to actually vibrate hard enough to make a unpleasant sound that can be heard.
Troubleshooting consists of finding (listening) the culprit and either replacing the part or in many cases Hot glue applied (some if a small coil or transformer will use super glue on the copper coils) to the exposed wires on the part.
Dec 21, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
How to change lamp
http://www.fixyourdlp.com/guides/samsung/bp96-00608a.php
This link will show you how to do this
May 29, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP No picture and very deep & lound vibrating sound. Red lights flashing,Sand By Temp. And Green lights flash Lamp.
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
Jan 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
