Question about Garden
Today when i started my mower,i push the lever down to go, but nothing .i can push by hand the wheels turn ,but engage it ,and it locks up. wont go.
  • 130 Answers
Not really sure dont know how its made.
but check drive belt for streshing
Posted on Jul 22, 2009
Why won't the mower move forward or backward even though the engine is running and the blade will engage?
First off, riding mowers do not "go into gear"; nor can they be shifted into or out of gear...nor, as a matter of fact are they "automatic" or do they have "automatic" transmissions. Instead, the so-called hydrostatic "transmission" is nothing more than the sense one gets--encouraged by mfr/seller misdirection (or product ignorance)--that a mower works just like a car...rather than being powered by nothing more than a belt that turns a wee little hydraulic motor, the speed and direction of which is controlled by the foot pedal controlling volume of fluid coursing though it to hydraulically drive the drive wheels.
If your rider will not move, that means one of two things (other than fatal failure mode)...or rather two of one thing, the latter being that hydraulic fluid it not flowing, is not pumping freely, through that motor.
Reason 1 (the more likely) is that the manual-mower-push switch on the motor has been engaged to permit the mower to be pushed without the vehicle (drive wheels) being blocked...because the engine is not running, so the fluid cannot flow with the turning of the drive wheels (unless the switch is engaged).
Think of it this way. When the mower is running and the clutched engine PTO is driving the belt or shaft that drives the hydraulic motor, the direction is chosen by reversing direction of fluid flow that the motor is circulating under pressure (also called pumping) to the drive wheels. Push toe and it flows and drives wheels in the mower-forward-drive direction; push heel and it flows the other way. Now, what about when neither is pushed? Then, essentially, all channels of flow are blocked--"neutral" (if you want to think of it that way) is not freewheeling (as with a car), it is drive wheel blocked by hydraulic lock at the motor. That is why a "hydo..." equipped mower does not coast as does a car. Alternatively, suppose that you could lift up and try to rotate the drive wheels in a particular direction. You would find that the wheels resist turning (unlike rotating RWD car drive wheels to remove a drive shaft, for example)...because they are essentially hydraulically locked by the motor that is not allowing compensatory fluid circulation in any direction!
Now, to disable the manual push mode that allows the drive wheels to rotate for manual pushing, look under the mower at the drive motor. It will be at the end of the belt loop or shaft being driven at the PTO beneath the engine. Now, find some kind of protruding lever big enough to grasp. If it seems "up" push it down; if "down" push it up...just make it go the other way to release. Now, start up and drive the mower normally. But wait! Before you mow, read the below.
Reason number 2 for unexpected drive wheel drive failure is absence of fluid to drive them....because you have not check fluid level and maintained it as the instructions directed you to do. So find the fluid plenum/level-check container and add some fluid if it is low. Just a little. Then start the engine and check lever with motor running. Fill carefully to indicated level but be very careful not to over fill. The mower should now run with valuable maintenance lesson learned. And remember that neglected fluid check can greatly shorten hydraulic motor life. Oh, make sure to check fluid level again when finished....after any air has been purged...add if/as necessary.
Nov 10, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I had a flat on my husqvarna yth 2748.. after i replaced the wheel and tire the transmission will not engage. Did i knock something loose jacking up the mower and removing the wheel? It was working fi
Two things to look for. 1. You may have not replaced the key in the hub. These keys slide out when you remove the wheel from the axle and have to be slid back in after replacing wheel but before you replace the washer and circlip. Test by jacking up the mower frame and see if you can rotate the wheel by hand. If it is easy you are probably short of the key. If it does turn but is stiff try # 2. There is a disengage lever or slide at the rear and low down on most hydrostatic drives. This is designed to let the machine be pushed in and out of its shed without starting the motor. It is easy to inadveryently knock this rod. It may be inside the catcher if a rear one is fitted.
Sep 28, 2014 | Husqvarna Garden
John deere 190c starter will not engage
If Your battery is Hot, make sure that the mower blade is dis-engaged, make sure nothing is under Your seat interfering with the seat safety switch and then be sure to push the brake down hard while You turn the key. God Luck!
Aug 19, 2014 | Garden
Toro zero turn mower wont move
there is a parking brake turn it off if that still dont work check your hydrolic lines
Jan 21, 2014 | Garden
Craftsman yts3000 riding mower
Probably wheel will turn individually but try both at same time and they will probably not move. Am sending you diagram of tranny maybe it will help.
Oct 02, 2017 | Garden
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
The blades don't engage when i push the pto switch on dash
Sounds like you have a loose or broken wire. It may have an inline fuse that blew. I would start at the switch and work my way down checking the wires for breaks or disconnections. If nothing, it may be your brake switch. If your brake switch is defective or not hooked up, your mower wont register you have pressed the brake lever and wont allow you to activate the mower deck as a safety measure.
Mar 30, 2012 | John Deere Garden
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Wheels lock when self propel not engaged
Hi
a;; you need tp do is loosen the cable slightly to the self drive mechanism
Apr 05, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
