Question about Cameras
The supacam ss stops working each time the charger was connected. It took several days with multiple attempts to have the camcorder works again.
  • 11,896 Answers
There is a problem with either the firmware or a capacitor. The system will need to be sent in for upgrade.
Posted on Jul 21, 2009
Delta Touch2O problems
YOU HAVE A COLD WATER RESTRICTION SOMEWHERE. THROW A DIFFERENT FAUCET ON THERE, AND SEE HOW THE FLOW IS. MY GUESS: STILL POOR....TRACE COLD LINES BACK UNTIL YOU FIND IT
Dec 20, 2013 | Plumbing
98 VW Passat. Started fine when I left work. Stopped at a gas station. When I went to start it again it would crank but not turn over. I tried several times and after 5th attempt it started. Got it home,...
Could be many things. I'd check the battery first. Make sure it's holding a charge/ not dying. There's several other problems that could cause this so check battery problems first. If it's not the problem, let us know. I/others can suggest other things to check.
Apr 07, 2013 | Cars & Trucks
My ice machine has stopped working. Is this something I can fix myself?
I had the same problem. I took the unit out for a day to let it completely defrost, then it worked again. I had attempted to take it out for shorter periods of time, but that didn't work.
Jan 01, 2010 | LG LFX25960ST Stainless Steel French Door...
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
I have a Sny dcr-hc48 camcorder which stopped working some time back. this week i had my friend who came with the same camcorder and i swapped in his battery and my camcorder started working. but if i...
First: put your battery in your friends camcorder and use ur friends charger to charge the battery.
Then put your battery back into your camcorder to see if it works.
If the battery works then this eliminates the battery as a problem.
Next plug your charger into your friends camcorder to see if it will power the camcorder without battery, if this works then the problem will most likley be the connector in your camcorder.
If this does not work then the problem will be the plug or the charger.
Next plug your friends charger into your camcorder if it does not work this will verify that the problem is the connector on your camcorder
binary6
Sep 16, 2009 | Sony Video Cameras
I have a Canon FS100 Digital Video Camcorder. I am attempting to download some video on to my iMac, but then I select "Connect To Camera" I get the message "No Camera Was Found". I have the camera plugged...
The computer is no longer detecting the camcorder for several reasons. It could be the ports on the computer, it could be the cable that you're using to connect the camcorder to the iMac, or it could be the camcorder itself.
Try connecting the camcorder into different USB or FireWire port of the iMac.
Try using different cable.
Try connecting the camcorder into different computer to test the device.
If all else fails, power cycle the camcorder by turning it off and remove the battery for about 10 minutes. Then turn it back on. Otherwise, contact the manufacturer for second opinion.
Hope these helps and have a great day!
Aug 12, 2009 | Canon FS100 Flash Media Camcorder
Problem with ATT cordless phone set (3 phones)
I wonder if any one who asked this question got an answer to this good question. I am having the same problem. I need some help.
Gene
Nov 26, 2008 | AT&T 2256 Cordless Phone
Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Feb 11, 2008 | Canon ZR300 Mini DV Digital Camcorder
Error code on DCR-TRV530 - C:32:10
Try taking out the battery and plugging in the charger with no battery. That did it for me.
Jan 26, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Help!Phone does nothing!
Ok you need to replace that charger cos thats the one that is doing all the damage. Check your battery voltage if its below 3v then you need to rejuvenate it back to its original capacity. It will be ok good luck.
Jul 02, 2006 | Samsung VM-A680
Cameras Logo
368 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
