Question about Roper REX3614KW Electric Dryer
What would cause intermittant heating in a Roper Electric Home Dryer?
Good morning, love this idea of helping people. Does anyone have experience with checking the heating element? Both fuses are working but oftentimes, we have to re-run clothes as its a hit or miss heating game. Any ideas on how to check if a heating element is actually working? Really appreciate any help. thx, Aimee
  • Anonymous Dec 22, 2007
    dryer runs but does not heat
  • 213 Answers
The dryer vent, not the parts behind the dryer, where it goes into the wall to where the vent leaves the house has lint build up in it. this will cause the element to short cycle cause long dry times. if its really bad ive seen people have to run dryer 3 or 4 times to get clothes dry. clean out vent. this should solve problem
Posted on Nov 21, 2007
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
I came home and my dryer had still been running for the whole time I was gone, about 4 hrs. The clothes inside were cold and not dry. This morning I tried getting it to work, but the clothes remained...
heatman101
Apr 23, 2011 | Roper Dryers
Roper Electic Dryer EL4030V - comes on - runs good - just no heat?Would like to try to fix myself? Where to find good instructions with pictures?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 21, 2010 | Roper Dryers
What can make my dryer stop heating or to heat randomly?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jun 29, 2010 | Roper REX4634KQ Electric Dryer
Roper electric dryer heats & tumbles but won't dry clothes
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 24, 2010 | Roper RES7646KQ Electric Dryer
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer fuses are always dying and I have no heat
The fuses are doing a  great job 4U, they burn up instead  of U or your dryer.
If you having this problem is because these a bad circuit, please be sure to talk to a relative or a friend about this electric issue.
I also found this
 (check that the fuses are firmly seated, clean the contacts if they look dirty).  Fuse contacts are not designed to heat up and will eventually "burn-in" when they become resistive.
Fuses will protecting you n your love once against fire because eventually wit out it will cause fire.
"Was this helpful?"
May 09, 2009 | Roper REX4634KQ Electric Dryer
Intermittant buzzing vibration like sound when drying.
Check your lint filter may have lint filter alert.
Apr 22, 2009 | Roper REX3614KW Electric Dryer
Roper Dryer will not heat
I don't have a picture of the rear panel available, but if you have to remove the exhaust duct to remove the panel, I would be checking to ensure the exhaust ducting is not clogged/restricted. The duct does not have to be completely blocked to cause the dryer not to heat properly.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | Roper REX4634KQ Electric Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Roper REX3614KW Electric Dryer Logo
392 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
