Mom had this laying around for a few years so I was trying to connect this for her 80th birthday. I need a 5th grader! haha
I bought the connector for the yellow, white and red output for the audio output and hooked it up to the "new digital converter box" and everything works okay except when I insert a audio DVD to hear, they is no sound.
I can watch the tv okay with sound.
I played the DVD on my computer and it works fine.
I switched the "s-video / componet" to componet and set "select progressive" to on and there is still no sound.
I did select DVD and not VCR.
Everything was unplugged before I connected the dvd / vcr. I even powered everything off and let it sit for 20 minutes and reconnected the power to the TV, converter box and then, dvd / vcr. No sound.
When I press PLAY, I can see the timer moving but no sound.
Any thoughts for this old fart will ge greatly apprecitated!
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Was this helpful?
Yes
No
Popular Solutions for Toshiba SD-V392 DVD Player /
after inserting the dvd movie the dvd lens emmits red lazer beams for 3 times then the cd stops...
(More)
after inserting the dvd movie the dvd lens emmits red lazer beams for 3 times then the cd stops rotating and no disc appears on tv
playing a dvd and the whole system powered off... not a power issues as all other appliances...
(More)
playing a dvd and the whole system powered off... not a power issues as all other appliances working. how do i get the disc out?
