I cannot connect my asus eee pc 904hd to the internet either hard wired to my modem, or through my wireless network. I bought it 2nd hand and the previous owner said they had no problem. I know my network is working because my mac and other PC connect fine. Please help - shaunnickless@hotmail.com
Asus pc Eee cant connect to the net
have you connect it with a network with your wireless? and does that connection connected succesfully?
or are you using modem? does the modem connected succesfully?
The url you try to go is valid,i've tried it
comment if you need more information
Aug 23, 2012 | ASUS Eee PC 900 PC Notebook
Can eee asus 1008HA laptops use a prepaid 'stick' for internet connection?
The USB wireless stick uses the cell phone network for wireless Internet connection provided it is within that ISP cell phone coverage area.
I doubt you can use a 2nd hand USB wireless stick unless the service is transferred to you. It is best you organise your own Internet connection with a ISP of your choice.
Laptop battery are removable and can be replaced when they are worn out, BUT the BIOS battery is inside the laptop and this can be changes but requires getting access to the insides of the laptop.
Apr 11, 2012 | Computers & Internet
Cannot get eee pc 1001pxb to connect to the internet. it has connected to a wireless internet, but not the wired connection. I have linksys wireless g router, but it is hard wired to all my computers. i...
Good Morning.
Do not worry, We will fix the issue for you.
Please open control panel >> network and sharing center >> if you see wireless network connection >> please disconnect it and >> connect the lan cable or wired cable to the laptop and start browsing.
This will fix the issue.
Jul 06, 2011 | ASUS Eee PC Netbook
Asus eee pc 4g wont connect to internet with
Can you connect through a "wired" connection? Is your router connected to the Internet? If you're using wireless encryption, have you told your netbook what that encryption key is?
Apr 29, 2010 | ASUS Eee 4G Notebook
I cant get wireless driver installed, Says driver not supported, Mine is xp sp3, where do I get wireless driver for Asus Eee Pc 904hd. Please help I cant carry external wireless device full time.. Please...
You can the wireless driver directly from Asus here >>>>>>>>>>
http://support.asus.com/download/download_item_dna.aspx?product=20&model=Eee%20PC%20904HD/XP&SLanguage=en-us&os=17
Regards.
Nov 17, 2009 | ASUS Eee 4G Notebook
It wont connect to internet on wireless,ive enabled wireless
The wireless drivers may be corrupt.
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again. Also please remember to turn on the switch or use a keyboard toggle to turn on the wireless radio.
Good luck.
Nov 17, 2009 | Asus Eee Pc 701Sd Notebook
Trying to connect asus netbook to wireless connection
If you open your Network window from the start menu, at the top you will see "Add a wireless device". Follow the instructions and this should get your wireless connection with WEP key add. (When you select your router, you will need the WEP key at hand. You can get this by going to the web page of your routers IP address.) Good Luck.
Feb 09, 2009 | ASUS Eee 4G Notebook
Pls help
configure wireless network
Press Fn (Function key) at the lower left hand corner and F2 at the same time.
select Internet tab>>click on wireless networks.
select the wireless network that you have, and click connect.
this is where you need to know what kind of encryption you have on the wirelss network.
select encryption type. (WEP, WPA or other).
enter passkey for the network, and Press OK
Sep 12, 2008 | ASUS Eee 4G Notebook
Won't connect to wireless internet
I just went to the properties on my wireless connection, went to the "wireless" tab, and switched the encryption type from WEP to WPA and now my wireless works.
Aug 01, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
