Question about Panasonic Lands Phones
Retail store phones, Panasonic VB- 44210A-B lost programing after power failure. Two out of 3 phones in store work properly. Please advise. Thank you
  • 2,359 Answers
Ok this is a 1 hour or longer job. I will do my best to make the steps simple and easy to follow.
I will include links to pdf text files and pics.
To prevent this power problem you should look into a battery backup system, UPS for short.
APC is the leading company for UPS. Get the largest capacity your budget can allow.
When the power return,it is possible to get a power surge and damage the phone in question.
If this phone is using the optional power supply (power pack) then make sure it's plug in a life socket.
It it still does not work then swap it with a good one. (your other two working phone)
If you are using a PBX box,then follow the wire of the bad phone and plug it into another RJ-11 jack.
or test the bad phone in a known good cable.
The price of VB-44210 is range from $59 used to $125 recondition now.
I strongly recommend you to do the steps above to verify the condition of the phone.
APC UPS is a must!
Please email me the result of these test.
I check my email my all day until 11:00pm PST.
Please keep me up to day.
Posted on Jul 21, 2009
  • Vincent_G
    Vincent_G Jul 22, 2009
    Hi
    Are you able to swap the phone and test the digital PBX port?
    Please email me if you still need my assistance.
How do I reprogram the speed dial numbers in my Panasonic KXT61610 phone system?
Try Googling (Panasonic)(KXT-61610)(manual) without parens.
Jan 23, 2018 | Lands Phones
Tip
Panasonic VB-43225 Station Guide Models: VB-42210 / VB-42211 / VB-42213 /...
Models: VB-42210 / VB-42211 / VB-42213 / VB-43220 / VB-43221 / VB-43223 / VB-43225 / VB-43233
Have you misplaced your Panasonic VB-43225 User Manual?
Would you like a digital, searchable, pdf version of the Panasonic VB-43225 Station Guide?
Follow this link to download a pdf version of the operations manual / instruction guide.
I hope that helps.
on Apr 17, 2010 | Panasonic VB-43223 Corded Phone
Tip
Panasonic VB-44225 User Manual Models: VB-44210 / VB-44211 / VB-44220 / VB-44223...
Models: VB-44210 / VB-44211 / VB-44220 / VB-44223 / VB-44225 / VB-44230 / VB-44233 / VB-44310 / VB-44320
Have you misplaced your Panasonic VB-44225 User Manual?
Would you like a digital, searchable, pdf version of the Panasonic VB-44225 Owners Guide?
I hope that helps.
on Apr 15, 2010 | Panasonic VB-44225 Corded Phone...
I have a panasonic A-616 after power failure the system restored but none of the phones will ring just the line lights flash
Either the software took a spike and jumbled up programming or the memory capacitor no longer functions.
Call a tech/vendor to reprogram and advise on future for power fails.
Jul 19, 2012 | Panasonic Lands Phones
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
Call Out line is lost
If you truly have a TD-816/1232 system consistent with the 74xx series phones, and not the 7130 you posted under, you need to find out what line you lost, or how another phone is programmed.
Go to a working phone, press PROGRAM 99 and the buttons on the key strip. They should say CO-001, 002, 003 etc. Now go to the non-working phone and do the same thing. A C.O. is programmed by the code 0 + the 2 or 3 digit trunk number, so you press the missing line button and dial 0-(0)01 STORE or 0-(0)04 STORE, depending on which end you lost it from.
Pick up the handset and hang it back up to exit programming.
Carl
Feb 13, 2009 | Panasonic KX-T7130 Corded Phone
Time and date
1. on/off 2. program 3. # # 4. # 5. # 6. 2 # 7. Set desired time. (May be in a 24 hour time setting so be careful setting AM and PM) 8. # 9. on/off
That's it!
Nov 05, 2008 | Panasonic VB-43223 Corded Phone
We have the Panasonic KX-T7433 model of phones at our office. Yesterday I set about to re-programme some of the extensions and now, as a result I have lost the outside line for the phones that I have been...
I just found this, which had the process for programming a CO button as a one-touch. And it worked. It's a bit easier to follow than the panasonic manual so hopefully it will have an answer.
http://www.command-a.com.au/Portals/0/Panasonic%20816%201232%20Quick%20Referance%20Guide.pdf
Jul 23, 2008 | Panasonic KX-T7433B Corded Phone
Panasonic VB-43223
This phone you have is on a Panasonic DBS phone system. The phone system can be programmed to have any combinations of telephones ring under different circumstances. If you can swap phones around (with another known working phone) and the phone at that location still does not ring then it is definitely in the programming for that location not to ring. The phone system would have to be programmed. In that case you would need to get someone (phone system installation company) familiar with the system you have to re-program it. A phone system Programming manual would be required (not a user guide).
Nov 12, 2007 | Panasonic VB-43223 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
