Question about Sewing Machines
Thread tension not right
Please help.I can't seem to get the tension right.
    Problem Solver:
  • 15 Answers
Take out the bottom bobbin and adjust this till it will not quite hold it's own weight when you hold the cotton and let the weight of the bobbin fall gently on it. adjust the top tension to suit.
Posted on Sep 06, 2009
Thread tensioner not working
Hai, Please see the right side and loose the tension, change the new needle. Otherwise go to mechanic shop.
Apr 08, 2014 | Baby Lock Sewing Machines
Thread tension
Needle/fabric/thread combination is wrong. hope this helps
Aug 17, 2017 | Sewing Machines
I cannot seem to get the top thread of my machine to pull smoothly through the tension disks. The machine was bought as JCPenney 25 years ago, no name brand-- Thank you!
Are you trying to pull the thread when the presser foot is up or down. Try this, rethread, then with the presser foot up, pull the thread it should feed smoothly, Now put the presser foot down, now the thread should barely move. Sometimes this seats the thread in the tension discs. Also, check your top tension control, I use 3 and maybe that will help you. Is your bobbin threaded right? Hopefully, this will help
Nov 14, 2010 | Sewing Machines
My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Jul 28, 2009 | Janome Mini Compact
Bobbin thread is pulling to the top, using embroidery needle, bobbin thread and proper thread on the top. As far as I know the machine is set right. This might not be the right place to ask, but am...
Setting bobbin case tension:
Put wound bobbin in bobbin case. Thread it in case. Hold the thread and carefully let go of the case only holding bobbin thread. The case should NOT move. Quickly let your hand drop 2-3 inches to let the bobbin case free fall for 2-3 inches, the bobbin case should move slightly then stop. It moves because it let’s a little thread off the bobbin. It should then stop .5"- 2" of thread should release. If so, your bobbin case tension is right. If it’s right then begin to look at your top thread tension. Always Always start with a properly adjusted bobbin case, then adjust your top tension accordingly.
Mar 18, 2009 | Bernina Artista 170
I can't seem to ever get the tension right on my "singer simple". no matter what i do, the stiching is a problem. this is my second machine with the same problem, is this a mfr defect or...
Probably operator error. Make sure the machine is threaded right, make sure the bobbin is threaded properly, change the needle.... even though you think the needle is sharp. Make sure you are using the right thread. If you have bargain thread, throw it out. Use Coats & Clark, which is still reasonably priced. My friend has a lower end Singer that was acting up ... loose threads on the bottom of the fabric, which means upper tension .... we did the simple thing of changing the thread. It worked, and the machine is sewing beautifully.
Apr 14, 2008 | Singer 3116 Simple
I have problems with my tension settings
upper tension needs to be tighter
Jan 16, 2008 | Sewing Machines
Sewing Machines Logo
67 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
