Question about Nordic Track NordicTrack Treadmill, A2550
Pro-Form 775 EKG Just stop milddle of running
When I set up speed 3, then it goes up 3.5 --> 3.8 --> 3.3 . after that I set up 4 , then it goes up 5.2-->4.8 --> 4.3--> so on. During the while running, the treadmill was stop. I don't know how to solve it. Could you please someone tell me how to solve this cause? Thanks
    Problem Solver:
  • 5 Answers
It seems a speed sensor feedback problem
if competent remove power supply to threadmill ,open covers and locate speed sensor on motor drive unit ,blow dry air using a suitable air compressor or just use a brush to gentle remove any deposits
close covers and retry
Posted on Jul 23, 2009
Breaker trips when running
Posted on Oct 16, 2009
Pro-form 650 cross trainer - when started the belt goes fast for 3 seconds and stops.
The Motor controller board is faulty. That's why its runs on the Top speed and and shut sown due to the over current consumption
You have to replace the motor driver or get it repaired.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 10, 2017 | Exercise & Fitness
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
How do I turn on my Pro form 760 ekg .
Dear Sir.
Please turn on the power switch that goes down in the machine is Red switch, most of time there some light of Neon that illuminated when you push to ON. Otherwise reset the button to the side to the power button.
If everything is o.k go inside of the machine and see if the breaker of fuse is tripped or blow, or corrored ( clean but disconnect the power cord): and try again. If not work. You must see if you have power from the outlet wall in your house and reset your breaker.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Proform Treadmill with iFit Live
My Pro-Form 770 EKG changes speed without direction from users. Any?
HI,
You have to check the speed sensor near the mottor pully. If the speed sensor is fulty or if its coverd with dust then speed can vary. Another reson for speed variation is the Faulty carbon brush in the motor. I have added the picture of speed sensor for reffarance . Also the link will help you for the regular maintenance of the treadmill.
How to repair treadmill
Ajin
Feb 27, 2012 | Exercise & Fitness
I have vista sp 2 64 bit running on my vaoi laptop. My laptop is extremely slow despite having a 4 gb ram. Even if i swith off the updates it shows me updates being installed on start up and shuting down....
Steps to speed up your computer
Operating system : Vista
1. Run Disk cleanup ( location : start> all programs> Accessories> System tools> Disk CLeanup )
2. Run Disk Defragmenter ( location : start> all programs> Accessories> System tools>
Disk Defragmentation )
3. Reset Internet Settings ( Start> Run , type : inetcpl.cpl and click OK)
- You will see internet properties.
- In the General tab> Brower history> Check delete history and click on Delete
> You see another window, check all the boxes, except : password and Form data.
- In the Advance tab> Click on reset ( make sure you have closed all the IE pages)
4. Delete Temp, %temp% and prefetch file ( junk files )
5. Visual effects settings : Right click my computer> properties > Advanced system settings
> under performance option click settings> uncheck all the boxes except the last two and then
click APPLY and OK.
6. If it's still working slow, need to change same settings in Registry and Msconfig
7. Reply back for more trouble shooting
Dec 13, 2010 | Computers & Internet
I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Jul 14, 2009 | Exercise & Fitness
Manual for 775
go to:
http://www.iconservice.com/manuals.html
fill out form......search.... view manual in PDF Format
Print
Apr 15, 2009 | Proform 775 Crosstrainer Treadmill - Free...
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Nordic Track NordicTrack Treadmill, A2550 Logo
1,186 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
