Question about HP Computers & Internet
Why can't I print an email to my new Epsom XP-245 from my iPad or my HP laptop even though they are both recognising the printer on the wi-fi network
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Try to reset and reconfigure your router.
Posted on Feb 12, 2017
  • 48 Answers
SOURCE: about wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Posted on Feb 10, 2008
honey2509
  • 146 Answers
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
  • 3 Answers
SOURCE: HP All-in-one printer C4180 network readiness?
the dell must be set to host or peer to peer on the network for the other computer to find it through tcp/ip or ipp protocol. it comesdown to software set up which is always the biggest headache second to the userintroducing a problem. good luck
Posted on May 10, 2008
  • 29 Answers
SOURCE: Having trouble with usr8054 wireless networking
Yes you should be fine. You have to configure the router before you can access the router, That should be covered in your manual. Also look for a button or switch on your computer that turn your wireless on and off. Make sure this is set to on.
Posted on Jan 15, 2009
  • 5 Answers
SOURCE: Can not connect to personal Wi-Fi network
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Posted on Jun 25, 2010
I have been using wi-fi printing on Samsung Galaxy 8.4 Tablet & now I'm unable to get my tablet to print.
Your printer may have changed it's IP address. This is a common occurrence on wireless networks. You should be able to get the new IP (to configure your tablet) by doing this on your printer: Go to the Home Screen --> Setup, then touch Reports and then select Network Configuration to see all of the printer's network details.
Mar 16, 2016 | HP Tablets & eReaders
Why is My HP printer not connecting to Wi-fi?
You sound as though you wish the printer to directly connect to the laptop via wi-fi. This is not usually the case in home networks. Most home networks use a wi-fi router to link all wi-fi components. This is because your laptop is not capable of handling the routing duties itself, nor is the printer (normally). The wi-fi router assigns the IP addresses that the devices use to communicate to the router and each other. That said, IF you ARE using a router, perhaps you are not entering the security code that the router needs to allow the device to attach to the network. If you are NOT using a router, then you still MIGHT be able to use the printer with the laptop if it has a "direct connect" capability. You would need to look at the printer documentation and instructions on how to set it up. Unfortunately, wi-fi isn't as simple as just turning it on an waiting for a connection to take place.
Aug 05, 2015 | HP Office Equipment & Supplies
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
My laptop and HP Deskjet 3510 All-in-one printer are on wi-fi networked to my wi-fi router. My problem is that when my laptop is connected to the internet my laptop is not able to communicate with my HP...
Okay... Sound to me like the DHCP Server in your router is off..
Well, do this or have your technician login to your Router admin page ( by typing 192.168.0.1 or 192.168.1.1, (or something similar depending on the brand and make of the router) into your browser and hitting enter) and either make sure Lan side DHCP server is on, or leave it off and just assign different static local IP's to each of your network devices ( e.g. 192.168.1.10 for you laptop and 192.168.1.11 for your printer). I think that will solve your problem if its related to an IP conflict.
Hope this Solves your problem. :)
Jan 07, 2014 | HP Deskjet 3510 e-All-in-One Printer
How to print from iPad CannonPIXMA MG3250
check your printer
1. do it have power.... power on an then power off see if this step resolve your problem
2. latest printer driver (update)
3. ipad + canon in same wi-fi network
4. enough paper
everything ok?
  1. Tap ht4356--alt--en.png or ht4356----en.pngbottom of your screen.
  3. Choose your printer, the number of copies you want, and then tap Print.
Jan 01, 2014 | HP Deskjet F4140 All-In-One InkJet Printer
How to make copies off of iPad using Hewlett-Packard printer 4620 with Wi-Fi
you would have to install the Ipad on your network.. you should be able to got to hte printers section in your Ipad then add a printer from network. Assuming the printer is already on the wireless network.
Jun 28, 2013 | HP Office Equipment & Supplies
I need a list of printers I can use with my ipad
Using google printing function you can print from iPad, via a second computer that is linked to any printer. I have old dell from 2006 that I no longer use. I connected it via wifi to my home network and it is linkrd to a Brother 2002 printer via USB. I then followed the google classic printer instructions to configure printing network. It worked well sometimes, I will confess that a times it is a pain.
May 29, 2012 | Apple MC705LL/A - The New iPad 3rd Gen...
How can i use my hp laserjet p1120w with my iPad by airprint
AirPrint lets you print wirelessly to AirPrint-capable printers. Make sure you have an AirPrint-capable printer.
AirPrint-capable printers don't require printer software; they just need to be connected to the same Wi-Fi network as your iPad.
If you're not sure whether your printer is AirPrint-capable, refer to its documentation or contact their support.
Here are the steps.
1. Tap (the back arrow) or (the forward arrow) (depending on the app you're using), then tap Print.
2. Tap Select Printer to select a printer.
3. Set printer options, such as number of copies and double-sided output (if the printer supports it). Some apps also let you set a range of pages to print.
4. Tap Print.
Dec 25, 2010 | HP LaserJet 1020 Printer
About wi-fi
Feb 10, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
