Question about Refrigerators
My SubZero is saying it needs repair however it seems to be working properly at this time. Do I need to call aservice tech or can I do some troulbe shooting before call one?
    Top Expert:
  • Refrigerators Master
  • 79,186 Answers
I assume you have a fault code, do you have good working knowledge and electronic testing equipment to troubleshoot this? if not u are better off calling a technician while the fridge still works, if the fault is serious it will stop shortly
Posted on Jul 21, 2009
Insulation breakdown
Hi.
I have not seen a subzero unit that could not be repaired, even thirty years old unit can be repaired. With that being said, I would call subzero directly to ask for a certified servicer in your area to take care of your unit. Here is a link for their website to help you Contact and Support they will get you a person knowledgeable to correct your issue. FYI not everyone can work on SubZero unit. This unit if 12 1/2 years old is just a teenager to this manufacture, no worries. They can last over 30 years, I have seen them and repaired them.
I am here if you need help in SoCal.
Jun 08, 2013 | Sub-Zero Refrigerators
Cd loaders will not work. It seems to be jammed.
If this is a multi disc system the plastic bays over time ware out along with the gears that run it, the repair is very difficult and usually impossible. The cost for repair will be high if the tech is successful, because he will need to dismantle and re-time the gears to work properly. I suggest an estimate before you commit
Jan 05, 2011 | RCA RS2010 CD Shelf System
The ice maker doesnt make ice and the vacuum condenser warning always is on. even when I turn off and on and vacuum
Your unit may still be under warranty- the following blog has the warranty lengths (in years):
http://applianceguru.com/forum1/16671.html
Here is a general ice-making troubleshooting guide that may help you:
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
Here's what a tech on applianceguru.com says about the vacuum condenser problem:
The vaccuum condensor light just means one or more compressor in the unit has excessive run time, you need to have this unit checked, your compressor(s) are running too long for some reason so might be a sealed systen problem developing.
Read more: Subzero says vacuum condenser - The Kitchen Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum1/2410.html#ixzz14kiAdO9r
Get appliance parts at http://parts.fixitnow.com Since you have a sealed system, a tech will have to come check it out and troubleshoot it. Hope it's still in warranty, and good luck.
Nov 09, 2010 | Sub-Zero 690 Side by Side Refrigerator
The #7 & RH SHIFT KEY DO NOT WORL ALL THE TIME. DISASSEMBLE THE KEYBOARD & CLEANED SEEMS TO WORK A LITTLE BETTER. WHAT PARTS DO I NEED TO REPAIR?
Try this unauthorised repair, pop the key top off make a small spitball and push it down the little hole in the hole and replace the the ket top. It should work. The proper repair is to replace the contact sheet. You need a tech for that.
DickyO
Aug 25, 2010 | Nakajima AE-740 Typewriter
The heat is not getting hot and keeps turning off
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Jan 31, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Coleman airconditioner continuously blows fuses
You might need a time delay on your uit to give it time to balance out. Also you may need a hard start kit for your compressor. I suggest call aservice tech and get a free estimate. Russ
Jul 26, 2009 | Heating & Cooling
Freezer not getting lower than -20deg
Three things bad defrost time bad defrost termination switch or bad heaters. You need aservice tech to check this out. Russ
Jul 19, 2009 | Amana SXD524VW Side by Side Refrigerator
Condensation and water in refrigerator
It sounds like you need someone who knows what they are doing out to your house. A tech should find and repair or replace the component that leaks. A second trip should be not be needed. The fact you have mold tells me they have never properly did your repair. Mold will grow only when the cavity gets above 40 degrees for a sustained period of time. use http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820 and explain the situation and get another company to fix it right.
Aug 17, 2008 | Sub-Zero 601R
Subzero 690 flashing EC and service
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
Mar 26, 2008 | Sub-Zero 632 / S
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
