Question about Canon imageRUNNER 5000 Copier
How add toner into canon imagerunner 5000?
I do not have the manual. Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
To add toner for IR 5000 just lift the small cover on right hand side then insert the bottle vertically see to it ,its in the notch and the bottled is locked then pull to the right the toner cover until sttop then the toner will drop on the hopper after the toner bottle is empty push back the cover then the bottle automatically unlocks ,removed and close the cover hope this help
Posted on Jul 22, 2009
Error code E-000013-0000 on a Canon Image Runner 5000
e-000013, it is all about waste toner.
possibility :
- waste toner case was detecred full.
- The PLL lock is released because waste toner motor is locked up, etc.
- The micro switch employed to detect clogging of waste toner is activated.
the position behind-below of copier.
open the beck cover and you ll see it.
the waste toner case
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
Sisa toner di sekitar cleaning blade mesin canon ir 5000 mengeras apa penyebab dan solusinya
bagaimana cara mengatasi kode error 804 pada canon ir5000, lampu scanner kedip-kedip pada saat mesin start.
Nov 21, 2010 | Canon imageRUNNER 5000 Copier
We have a Canon Image Runner 5000 and we just installed the toner but now can't get the toner bottle/adapter back off of the machine.
...check the hopper connector if connected...then install a toner by pressing *28*then copier then function then install...then press the ok in the rigthside of the screen
Sep 30, 2010 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
Toner out light
Open an close the front door on the machine a few times and it will add enough toner to extinguish the toner add light.
Feb 17, 2009 | Canon ImageRUNNER 1670F Copier
Adding toner to canon imagerunner 2200
if you have the toner open the front door take toner out of box turn the blue handle on the right side of the copier down which will move thr hopper. pull out the hopper till it stops . take the bottle and line it up so it snaps in place when it snaps in a little tab should pop put pull the tab till it says stop . This process opens the top of the hopper and bottom of the bottle then using your thumbs push the tabs on the front which closes the bottle back. then give it a little extra push and the boyyle will click off
Nov 12, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir5000
assuming it is a black patch of toner, the drum blade needs changing or the waste toner mechanism needs to be looked at
Aug 27, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 scanner
yes it can if you have the scanner driver borad loaded in the machine
Thank You,
Mikey
Apr 03, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
289 people viewed this question
old marine
old marine
