Question about Acer Aspire 5630 Notebook
My friend's 5630 has a very dark screen, but when it is fully charged, the screen is bright. Is this the video card?
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
I have an acer aspire 5630 it has worked well for nearly 4 years, about 4 months back I noticed that the screen would be dark and slightly reddish for the first 30 seconds to a minute after turning it on...
hi
try rebooting the system (i think its F8, to get to SAFEMODE) . in DESKTOP , right click and go to PROPERTIES, go to SETTINGS, go SCREEN RESOLUTION and take the arrow to the left ; set to 640x800 and and take the color setting to 256 drop down . hopefully this works after rebooting the system. if it doesnt, it may sound like the inverter card may be bad (PC bourd that connectes to the screen : this requires a service technician)
good luck !
Dec 09, 2011 | Acer Aspire 5630 Notebook
Power problems
check inverter board.
Jun 01, 2009 | Acer Aspire 5630 Notebook
Power saving problem
wait for your computer to die open it up log on go to the desktop right-click > Properties > Screensaver > Power... and set all to "Never" and your done
Adjusting screen brightness
If you hear the hard drive spinning and you think Windows is working but you can't see an image or a very dim image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Acer Aspire 5630 Notebook
My acer aspire 5630 laptop has a very dull/dark viewing screen it is fully charged and on high performance, help plz. Cheers G.
check on the keyboard, lots of the keys have an extra function, normally written in blue.
Look for the two that show brightness... it the same symbol on TVs that sets brightness...
now look for the "FN" key.
press and hold the "FN" key and then press the brightness + key... this should make the display brighter...
Dec 09, 2008 | Computers & Internet
Dell notebook lcd scren
Make sure its not in hibernation,check brightness with darken and brighten buttons,does backlight work.Try hooking up external monitor and see if you get video.Other problems could be drivers.bad inverter card,LCD cable,LCD display,system board.
Mar 25, 2008 | Dell Inspiron 1501 Notebook
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
You press the function (Fn) key and the left/right arrows, not the Ctrl / Alt, shift buttons
Oct 26, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
