Hello I have a Panasonic-Viera-Th-L42et5a and I need to figure out how - if I can use the TV controls to get main menu to connection internet as i have no remote
Hello: This procedure will bring up the self test screen and reset the unit to factory settings for you. First produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Forced to factory default:press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset. If it does not help, the main board need to replace. For further questions, please add your comment.
did you see the standby light? if no you have problem in main power
section maybe the fuse is blown you can locate the fuse at the power
main board, or if the standby light is light up the problem is the
inverter power supply and this section is need to diagnose to find the
defective parts...
Panasonic
TH-42PZ80U
Enter Service Mode InstructionsWith TV on, press and hold the volume down button on the front of the TV, and press info three times on the remote.
Select Category Instructions1 and 2
Change Data Instructionsvolume up and down
Exit Service Mode Instructionspower down
Menu Categorywb adj
Menu Itemsrgb cut rgb drive all cut all drive -->do not use these unless you need to match ywo displays side by side.
