SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
SOURCE: Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
SOURCE: The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions. If the grinder cleaning does not work.. You may have to have to machine serviced. Please include the model of machine and that you would like the grinder cleaning instructions. Email: [email protected]
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
SOURCE: XP7230 does not work with Claris F088 filter cartridge installed
You have the filter screwed it too far. As soon as you feel the filter seating do not screw it in any further.
