Home | Tally | Matrix T2280 Printer | Printer-Genicom 228...
Tally Matrix T2280 Printer
Problem for Tally Matrix T2280 Printer
Printer-Genicom 2280+ Printer stopped then
By ann_sviridov on Jul 21, 2009
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
Solution #1
posted on Sep 21, 2009
Somewhat Helpful)
Jamming
Rank: Guru  Tally Expert
Rating: 93%, 19 votes
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Was this helpful?
Yes
No
Popular Solutions for Tally Matrix T2280 Printer
Questions and Unsolved Problems for Tally Matrix T2280 Printer
Do you recommend Tally Matrix T2280 Printer?
Answer
Answer
Hi, Iam Having problem to work with tally 4.5 in xp giving the error message that insufficient dos... (More)
Answer
Describe your Tally Matrix T2280 : power up printer comes with THS ERROR 001. but still able to come... (More)
Answer
i cannot attach any file to sent e-mail
Answer
I have a tally printer that needs setting up. Can someone help with the procedure for setting up... (More)
Answer
T2280 Sprintpro Printer is giving AGA error
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tally Matrix T2280 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
