Whatever game I may be playing on my xbox 360 (mostly Gears of War 2 or COD 4), my tv screen will go fuzzy after about 10 minutes of play. This obviously makes it nearly impossible to continue playing because I can barely see what I am doing on my tv screen. As I continue to play, my tv screen will return to normal for a few seconds, only to change back to the messy fuzzy screen. I know for sure that it is my xbox 360 itself, because the problem has reoccured on multiple television sets. Any help would be greatly appreciated! Thank you!
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
I have the same problem with my xbox it makes the t.v fuzzy i know its the xox because i also have tried a different tv it stops for about 5 minutes then continues again i go to display settings but cant find that intermidate option your talking bout HELP ME
