Question about Verona 34 in. CTG536S Gas Cooktop
Why is the light burning on my Corning glass cooktop?
One of the burner indicator lights has been on for at least two weeks. The burner is not on, is not warm. The control knob is on "OFF". I have no idea what to do.
  • 153 Answers
Well there is some problem with ur knob u should replace it.
Posted on Jul 21, 2009
Indicator light on my maytag electric smoothtop range will not shut off even though the indicators are off?
One of the high heat sensors has failed on one of the burners under the glass. Disconnect one sensor at a time to find out which one, then replace that burner assembly.
Feb 19, 2011 | Maytag MEC5430BDS Electric Cooktop
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
GE Profile glass top cooktop- burners do not heat, indicator lights do work
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
Mar 09, 2010 | GE Cooktops
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
I have a corning 3+1 cooktop and the burners wont turn off .
replace the switches, its easy to replace,call the service center to get the part to replace,if very expensive,buy an ordinary switch,put in the wire of ur unit.every time u use it turn it,or buy a plug or an adaptor have switch at the side,make sure the adaptor is fit in ur unit.
tnx gerbee
Sep 04, 2009 | Cooktops
Hot burner indicator light won't shut off
the switch for the bottom right burner is bad but doent not affect the cooking, just the light
Nov 26, 2008 | GE 30 in.JP950 Electric Cooktop
Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Oct 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
Jan 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Verona 34 in. CTG536S Gas Cooktop Logo
133 people viewed this question
Top Verona Cooktops Experts
Steve
Bosse Photos
Pierre Legault
Are you a Verona Cooktop Expert? Answer questions, earn points and help others
