Question about Apple 13.3 MacBook Intel Core 2 Duo 2.0GHz, 2GB, 250GB, SuperDrive - Aluminum Laptops Mac Notebook
Keyboard and trackpad got wet
Some water splashed on to my macbook 13in and now the keyboard and trackpad doesn't work but everything else is fine. I'm able use it using usb keyboard and mouse but how to I fix the keyboard and trackpad on the laptop?
  • 33 Answers
It may work when it dies out...otherwise you will most likely have to take and have the keyboard replaced
Posted on Jul 21, 2009
Mouse pad keyboard mac accessories trackpad ibook
I've had this problem before. I had to get the trackpad replaced. Luckily I had AppleCare at the time.
Dec 21, 2013 | Apple MacBook Pro A1260 Laptop LCD Screen...
GE 97986 mouse and Macbook Pro
try a hp mouse it worked for me
May 25, 2012 | GE ho97986 Mouse
Keyboard &trackpad not function
The drives for Trackpad an key boardare courrepted.It better if you run an archive install to re write the drivers.
Apr 04, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
My keyboard & trackpad not functioning
Try format your laptop if that's ur suspect in dis-abled keyboard. If not successful, maybe the controller chip of the keyboard is defective, or try other keyboard for ur laptop, go to laptop repairshop.
Apr 04, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hi - I have a macbook and seem to have locked the keyboard - if I plug a mouse in at the USB it works but the mouse on the macbook isn't responded, nor are any of the other keys - is there a simple...
Hello sarahscarah,
I've repaired a fair share of Macbooks with the same issue, but just to make sure it is what I think it is I'll need you to do a few things.
This issue is thought to be caused by a bent/warped ribbon cable that is located under the battery. This cable is what connects the trackpad and keyboard to the rest of your computer. To test if this is the problem do the following.
  1. Verify that an external keyboard and mouse will work with your Macbook when plugged in to a USB port.
  2. Connect your Macbook to your power adapter and plug into wall.
  3. Unlock your battery by turning the dial on the bottom of your Macbook with a coin.
  4. Remove the battery and set it aside.
  5. Press down on the exposed trackpad cable with your finger.
  6. While pressing down on this cable try typing on your Macbook's keyboard and moving the cursor with the trackpad.
If this works then you've solved it, you can place a piece of "Kapton Tape" over this cable to hold it down, but this is a temporary fix. You will probably need your trackpad and keyboard replaced. If your macbook is still under warranty take it to an Apple store, show them the problem and have it fixed or replaced. If its out of warranty you'll be looking at a $200-$300 repair to have the trackpad/keyboard replaced by a technician.
Here's a picture of the exposed trackpad cable for reference.
Trackpad Cable Pic
Hope this helps, if so please leave positive feedback. Thank you.
Feb 16, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My keyboard got wet!! both keyboard & trackpad won't work
You may haveto get your keyboard replaced, an issue that would be addressed by theApple Genius bar2_bing.gif. If you are out of warranty there are Mac Repair Guides that show you how to replace the entire keyboard. Or you can go many third party Mac2_bing.gif Repair places. iSlate Repair.
Jun 17, 2009 | Apple MacBook Housing, Top Case with...
?have 17 inch macbook pro and 24 inch apple monitor, also apple wireless mouse and keyboard. Every once in a while the mouse and keyboard lose connection but the trackpad works with the monitor along with...
If you have "good batteries" installed in the mouse and keyboard and you still have the problem- the best way is to remove the devices via the System Preference panel in your MacBook and then re-install them again. It is important that you remove them first as the system may revert to the previous connection. Good luck!
Apr 29, 2009 | Apple Wireless Mighty Mouse
Tap feature on MAcbook 2.4Ghz 2GB
I am running mac OS 10.5.5 and Win XP using parallels.  You need to make sure the system preferences in the mac OS to allow two fingers for secondary click using the trackpad. This allows you to right click in Win XP.
I find using two fingers and clicking the button works more reliably in windows xp.  I usually have to try two finger tapping a few times.
To right click by tapping: Go to System Preferences and choose Keyboard & Mouse.  Select "Clicking" and "Tap trackpad using two fingers for secondary click". This allows you to tap the trackpad with two fingers side by side to get the "right click" effect.  You can also right click without tapping with this setting.
To right click without tapping:
Go to System Preferences and choose Keyboard & Mouse.  Select "For secondary clicks, place two fingers on the trackpad then click the button". This allows you to right click by placing two fingers on the trackpad and then clicking the mouse button. 0acf97a.png
Oct 23, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac Notebook
Hi there
One of the easiest questions I've had to answer.
From what you say you do not need a high end spec.
A 13in macbook should suite you fine. In terms of cost it is the cheaper mac. The screen size can be a hassle but all you need to do is buy a separate monitor to complement the 13in screen. So when you are at you desk you run dual monitors and when you present you use the macbook.
I'd just recommend to upgrade the ram and hard drive. Presentations such as powerpoint are memory hungry.
Paul
http://store.apple.com/us/browse/home/shop_mac/family/macbook?mco=MTIyMTM
Sep 08, 2008 | Apple MacBook Mac Notebook
Macbook trackpad tapping
Check in system preferences under keyboard and mouse in the trackpad section. You'll probably find that the trackpad taping will become annoying when typing but you can also enable two finger scrolling there - which you're should probably have.
Jun 20, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple 13.3 MacBook Intel Core 2 Duo 2.0GHz, 2GB, 250GB, SuperDrive - Aluminum  Laptops  Mac Notebook Logo
1,056 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
