Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Poulan Featherlite XT200 Grass Trimmer
It started out with just the pull cord coming out, it didn't break it came out in one piece.
I contacted customer support and they tried to help but things got worse. the pull coil has now come out and it's now uncoiled.
I would like to know how to fix all of the above and get my trimer working again.
  • nathan_jo207 Jul 21, 2009
    thx for your help, I'll follow your instructions.
    Have a great day!
  • 3,037 Answers
Well, ok, you may want a helper with this. First thing you want to do is to get the pull cord/rope put back through the hole it gets pulled from and then would around the pulley and tied through the hole on the pulley into a knot that keeps it in place. Then you need to start rewinding the coil where it goes inside of itself and position the ends of the coil into their respective slots that makes the pulley spring back which is where you should have a helper help hold it in place so that the coil doesn't out, you will want it to have a little tension on the coil so that the rope fully retracts (it is kindof hard to explain, I wish I could show you). The coil will be the hardest part of this and may take multple tries to get it into place. I hope this helps as it is hard to explain this but it is a simple design that takes time to get back together. If you have any specific questions about this and think a picture would help, then please post the picture of the area in question with the question in your next reply. Let me know how this turns out.
Benjamin
Posted on Jul 21, 2009
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Does poulan featherlite weedeater have a compression releif valve
It barely has a motor. No it has no need for compression relief.
Aug 11, 2012 | Poulan Featherlite Plus Gas Trimmer
How to replace the pull cord on model featherlite 71188
how to remove and replace the starter pull cord on a palen100 , 16''
Jun 11, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Engine start procedure for grass trimmer 350 L x series
  • With the trimmer placed on a level piece of ground press the primer bulb about 10 times.
  • Open the choke.
  • Press the throttle and lock it in place with the lock button
  • Pull the start cord until the engine catches. It doesn't matter if it cuts out again.
  • Close the choke, and if the engine did cut out the first time, pull the start cord again. This time it should start and you can start trimming the grass. If it didn't cut out just close the choke and you're ready for trimming.
Apr 06, 2011 | Husqvarna Garden
I have old poulan weedeater featherlite grass trimmer. wasn't used for many years. I replaced lines and bulb which were dried out and cracked. opened up & cleaned up carb -gaskets seemed to be in...
Did you check for spark? Try starting fluid to see if you could at least get a hic cup? Almost sure that your issue is carb related and you may have to replace it if it is not an ignition problem.
Sep 19, 2017 | Poulan Garden
Hello, I have a featherlite gas blower. when pull
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 29, 2009 | Poulan Featherlite Gas Blower, with Low...
Pull Cord Will Only Pull Out 3-4 Inches Then Sticks
Take it apart as you did before. Look for whatever it is binding. Did you rewind the rope so there is a good amount of tension? If you didn't, then do that . Good luck, Lee
Sep 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
137 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
