Question about Jeep 10 x 20
Engine replacement I want to replace the VM 2.5l engine on my Jeep Grand Cherokee limited 1996. I cannot find a similar engine where I am and would like to know which other engine will fit and what i need to do to achieve an easy replacement? thanks.
    Problem Solver:
  • 15 Answers
Re: engine replacement
Look at engin makes from , dodge and cvhrysler but i would suggest you look for the chrysler voyeger lx model engin since they are simmilar in engin capacity . if that doesnt work out try converting a similar chgeaper engin , i know it sounds complicated but its really easy i did it on my vw golf , its all about the gearbox joining the engin and getting the engin moutains in place thats where the challenge is other than that its easy and convinient ...... thank you please return the favour
Posted on Nov 29, 2007
0 characters
3 Points
My 1998 jeep grand cherokee only blows luke warm air even if I let the engine run for a while before hand. what's the problem?
If the blend door is allowing hot air to go from the heater core to the interior, then the heater core is likely to be clogged. Flush or replace the heater core that is clogged.
Jan 21, 2011 | Jeep 10 x 20
99 jeep cherokee not getting any heat. New waterpump and thermostat. System flushed and has flow. Heater hoses and upper radiator hose hot, lower hose warm. Any way to bleed air out of the system?
With engine cold, remove radiator cap, start engine, if there is air in the coolant system it will "burp" it out through the open radiator cap. Check fluid level and replace cap.
Good luck
Jan 31, 2010 | Jeep 10 x 20
Heat comes out driverside/cool air comes out the passenger side?
It sounds like your blend doors are broken. As it turns out, this is a VERY common problem with grand cherokees. My father and I fixed this problem on my 2001 Jeep Grand Cherokee Limited 4.7 about 2 months ago using a product called Heater Treater, found here:
You can find a very helpful detailed write-up of the fix/installation here:
Trust me, this REALLY works and a lot of Jeep Grand Cherokee owners, including myself, have done this. YOU WON'T HAVE TO REMOVE YOUR DASHBOARD, as the repair is done by simply removing your glove box. The downside is that you will lose Dual Climate Control, as the driver side thermostat will now control both sides. For me, it was worth it. Only spending about $150 for a Do-It-Yourself solution, versus spending about $1000 to have a mechanic remove my dashboard to fix it.
Dec 05, 2008 | Jeep 10 x 20
i have the same problem with a 1997 jeep cherokee country
Aug 29, 2008 | Jeep 10 x 20
1994 Jeep Cherokee
Check your alternator
Apr 03, 2008 | Jeep 10 x 20
1992 jeep cherokee
You gotta be specific. coulda be fouled plugs, tranny, coil.
Jan 28, 2008 | Jeep 10 x 20
92 Jeep Limited
Just out of curiosity. Is your Jeep an automatic or straight drive?
Dec 11, 2007 | Jeep 10 x 20
No Heat in 1990 Jeep Cherokee
well the first thing i would suggest is you take a look at its thermostat that could be over regulating hot air from flowing tothe heater if thats not got any major effect then have you been using an anti freeze formula for your engin coolant , because if not then it means the hot water pipes to your heater are blocked thank you.... if this was to benefit to you pease return the favour with a posetive rating
Nov 29, 2007 | Jeep 10 x 20
1982 Jeep Cherokee no heat
if you can hear the motor(fan) spinning, check the linkage that controls which vents are open, also check for a vacuum leak as the vacuum hoses on a jeep that old go out frequently and many times control the switching for the heater/defrost/ac. your first thing to do will be to grab a manual for this jeep and check the actual location of the heater/vent/ac fan. there is always the chance that the fan slipped off the motor (usually doesn't happen, but the circlips have been known to fail)
have you tried it in any other position? ie: vent or ac
Nov 21, 2007 | Jeep 10 x 20
94 jeep cherokee manual clutch fluid tube
easist fix is to visit a car junkyard and find a 94 jeep cherokee (or close to same year). remove the tube and pay the junkyard dog on the way out. Chances are the tube in the junkyard may also be developing a hole, so carefully inspect it before settling. Many tubes on cars today are metal that are covered in plastic. To remove it, keep in mind that it was installed at the factory, so removal is just the reversal. Look for a swivel connector at one end of tube (or both ends). This swivel connector is identified by a hexagonal "nut" and a "break" immediately next to it. This is actually a compression fitting that when tightened, forces two metal surfaces against each other that are tapered inside (look for this taper once removed). Now using an open-ended wrench, turn the nut loose while holding back rotation on the tube.
Aug 17, 2007 | Jeep 10 x 20
Jeep 10 x 20 Logo
66 people viewed this question
Top Jeep Binoculars & Monoculars Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Jeep Binoculars and Monocular Expert? Answer questions, earn points and help others
