Question about LG 50PX5D 50 in. Plasma HDTV
No component working on my LG 50PCD5
My TV turns on and everything else but it seem like all my connecting component can't seem to detect at all. Anyone Have a solution to why none of my component is not detecting when turning on the TV
5 Suggested Answers
dave08
  • 83 Answers
SOURCE: my 37" LG cannot detect my Fijiutsu siemens L7320 laptop
need to go in to your laptop to see devises to enble laptop to tv
Posted on Jan 14, 2008
SOURCE: Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Posted on Mar 20, 2008
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
  • 441 Answers
SOURCE: The tv screen says no signal, stuck on component 1
you need to change inputs, if the remote will not do it try the controls on the set, if thar does not work unplugg it for an hour and try agian
Posted on Jul 07, 2009
How do I fix my LG 50PCd5 Plasma TV?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 11, 2017 | LG Televison & Video
LG TV turns on but screen is blank, only sound is there
The days of real techies who can make actual repairs is long gone. Nowadays, they simply find out the board that is responsible for the problem and they replace the entire board. And often those boards can be pretty expensive. U have any idea of just how much labor is involved in checking those boards out? And how do you remove and replace a 20 leg IC chip? Vey few discrete components today and too many all encompassing chips!
Often if you know the part number U can get the part on the cheap on ebay, either new , or used.
Aug 19, 2015 | LG Televison & Video
Connect toshiba satellite l305-s5919 to tv with vga to rca cable
that particular model of computer l305-s5919 has RGB component out while the tv seems to be rca input.
does the tv have component in.
you may find an adapter like this might work
http://www.ebay.com/itm/Ypbpr-component-to-Composite-AV-RCA-audio-video-converter-with-power-supply/272260592065?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44770%26meid%3D75516a845eb841a3bec53062c7dfac66%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D230912528485
Jul 13, 2017 | Lifetime Computers & Internet
Lg plasma tv wont turn on
if the tv unit goes to safety mode after you turn on that was mean an error was detected. check for bad component parts at y and z sustain board.
Sep 15, 2012 | LG 50PG20 50 in. Plasma HDTV
LG LCD TV HDMI port not working
Have you tried rebooting the tv with the laptop on so that it can possibly detect the laptop?
Mar 23, 2010 | LG 42LC2D 42 in. LCD HDTV
TV doens'nt start
Take to repair shop, must have a loose connection. I am an electronic Tech, 20 years experience. When you turn on a late model TV they do a self test and if they detect a problem then they shut down. I'm not really up on LG, I work for Panasonic and our LED's flash, and depending upon number of flashes it tells you where the problem is. I would suggest phoning LG for the address near you of their Authorized Service Agent. Get the guys who fix them everyday to do the job.
Cheers
Gordon.
Sep 27, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Screen Gone
reset your diaplsy setting s to factory defaults.
also check your power supply waltage and earthing properly working
Oct 25, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Dec 07, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 50PX5D 50 in. Plasma HDTV Logo
52 people viewed this question
