Question about Dryers
Fan will not spin unless kick-started
I've got a small white box-fan that used to work great, until I cleaned it. After that it worked for a few months and then slowed to a crawl, then stopped. When turned on, you can hear it buzzing, and if held at a certain angle the blades will slowly turn. If you push the blades enough it will start moving normally. (albeit with the annoying buzzing) If you turn the fan sideways it stops again.
I opened the fan and took the entire assembly apart, and everything looks to be in one piece (although a nut was loose) The electric motor gets extremely hot when turned on. There seems to be a problem with the magnetic "catch" of the motor. The spindle part can be rotated freely by hand when the fan is off, but when I turn the motor on (and this is with the blades removed so it's not "over-weighted") it grabs the center magnetically and doesn't want to spin it. The center WILL slightly spin if pulled out from the surrounding electromagnet a little. Any ideas what's causing this or how to fix it without replacing? (with my minimal electrical knowledge)
  • zabeus Jul 22, 2009
    Thanks wiz protek480, you were exactly right. I had oiled them but not enough. It was a combination of that and the fact that the bearing wasn't secured strongly enough. I had no idea that the end-brackets actually had to be screwed in *tighter* for the fan motor to spin. Thanks for helping me fix it!
    President:
  • 1,714 Answers
The bearings are dry. They are not really made to re oil. You can try...Try to take the ends off and get some 3 in1 oil in. That's all it needs
Posted on Jul 21, 2009
    Problem Solver:
  • 14 Answers
You either have a bad capacitor, bad bearings, or it needs to be oiled.
Posted on Nov 29, 2011
Toshiba TLP-T60M fan error
I just had the same problem, you have an idea on this?
Nov 26, 2012 | Office Equipment & Supplies
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
With my thermostat on auto and on heat, and the furnace turns on, the fan will not turn on with it. If I switch the fan to on it will run after I repeat back and forth from auto to fan on several times...
Well, here is the deal: unless you rewired from two wire to multiple (usually 4 to 10 wires) wires, the fan cannot be controlled from the thermostat, even though the thermostat indicates that it can > it is a physical wiring and fan administration issue.
Unless you have a newer furnace, the fan is controlled by plenum temp. Works like this: burner turns on, no fan until the plenum temp reaches set temp,....then burner off, and fan keeps running until pelnum temp drops, and often the fan may kick on a few more times as this temp depletes.
Oct 03, 2010 | Honeywell Electronic Programmable...
Radiator fan not working
Be sure the wires are hooked up, and it may not have gotten hot enough to turn on the fan in just a few minuets. Ride it close to home, up and down the street for a bit to see. Just do not go far until you know for sure.
May 19, 2010 | 2000 Suzuki VZ 800 Marauder
Can't get temp in fridge to go below 50 F. Freezer works fine and makes ice. It started when our area had a heat wave and the inside of our house was 85+ most of the day. The ice maker stopped working,...
Have you checked the evaporator fan(freezer fan), This problem is hard to detect because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator.
Aug 01, 2009 | Refrigerators
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
96 Tahoe heater air con fan on the fritz
This sound like the windings in the motor are bad. If you are getting power to the motor in all speeds, motor is probably bad. There is a relay that is located behind the glove box. The glove box usually just snaps out by gently flexing in the sides. The relay is mounted on a bracket. Small, black, and square. Don't over look a bad switch either.
Good Luck
Feb 17, 2009 | 1996 Chevrolet Tahoe
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Dryers Logo
608 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
