Question about Brother HL 1240 Printer
The alarm light is on. Checked everything nothing seems to be wrong. I even changed the toner, which was not necessary
  • 336 Answers
According to the manual, which you can download from http://pub.brother.com/pub/com/printer1200doc/Eng1030ug.pdf, if the alarm light only flashes, then the fault can be viewed on screen or printed out. If all the lights come on and then just the alarm light flashes, then it has a rom fault and needs a service.
Regards,
Jeep Brainy
Posted on Jul 21, 2009
HP LaserJet 4250n Printer all pages blank even with new toner
Have a service tech check for the presence of the hi voltage applied to the paper to attract the toner.
Mar 10, 2017 | HP LaserJet 4250n Printer
Turn key on no lights at all
Harley Davidson Wiring Diagrams and Schematics
Hi Anonymous, check for continuity on "ALL" your relays and light fuse on "BOTH" sides, you may also need an alarm reset, for a free wiring diagram please visit the website below. Good luck and have nice day. Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Mar 28, 2012 | Harley Davidson XL 883C Sportster Custom...
My Samsung CLP 300 shows a red light. I've cleaned the toner tub and checked for paper jams, but still no results. How do you use the laser printer to check what's wrong? Any...
The red light stays on even in cases there's a paper size mismatch, and press the GO/START button usually helps. Also, it may be an indication that one of the toners is empty. See the level of the toner, the printer control program does this. If nothing seems to be wrong but you still have the red light on, unplug the power cord and plug it back in after a minute. Hopefully that may help.
Jan 18, 2011 | Samsung CLP 300 Laser Printer
Paper keeps jamming. It seems to get halfway through the toner and then the jam alarms go off.
Poor line condition. Everything is plugged in fine. Could my settings be wrong?
Mar 12, 2010 | Brother IntelliFAX 4100 Laser Fax
My MFC-7820n was printing perfectly and now, suddenly, all pages are very light and most toner doesn't seem to be fusing to the paper. The page 'sort of' prints but it's illegible. I have installed a new...
If the toner is not getting completely fused to the paper (i.e. you can rub it off with your fingers either completely or partially), then there is something wrong in the fuser section. The fuser is nothing more than two rolls pressed together with heat lamps inside (usually just one roll has a lamp). Perhaps a spring fell off? or the lamp is burned out.
Dec 06, 2009 | Brother MFC-7820N Printer
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Clicking Noise Coming From Under The Hood
Have you checked your belts? A piece of belt may have come off and been slapping under your hood, and then fell off completely. While it was slapping, your computer would have detected the slow down of pulleys etc. and caused your engine light to come on. Then when the piece broke off, everything would be back to normal. Let me know!
Apr 08, 2009 | 1998 Lincoln Town Car
Toner Missing Light Error persists
use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridge.
Feb 03, 2009 | HP LaserJet 1320 Printer
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Samsung ML-2510 Red light on & won't print.
This may be a help. I had a similar problem with an ML-2850 which fresh out of the box refused to print, not even a test page, green light followed by red and the smart panel showed that the printer thought that there was no toner in it.
After struggling with it for an hour I hit upon the following.
Turn off the printer.
Take out the toner cartridge.
In the hole where the toner came from there's a gear on the left hand side which is sort of diagonal mesh to match the underside of the toner cartridge. Rock it back and forth a bit and then stick the cartridge back in.
My guess is, if you're unlucky when you install a new cartridge you could have a situation where the gear is in exactly the wrong position, tooth to tooth with the underside of the toner so this gear doesn't mesh properly, the cartridge doesn't seat properly, which then shows the printer as having no toner in it. Waggling the gear just changes the position slightly and then voila. A bit like rocking a car back and forth in gear to free a stuck starter motor.
Mar 28, 2008 | Samsung ML-2510 Laser Printer
Brother HL 1240 Printer Logo
44 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
