Hi,i got a problem with one of my technics 1210 mk2.Sound on the right monitor is ok,but there is not sound at all on the left monitor! I try to replace the stylus,but nothing....Please help?
    Scholar:
  • 113 Answers
Hi the only thing in between is the cartridge, wires and phono plugs at the back. There is a small circuit board (no electronics on it though) inside that the wires go to first. The possibility are , cartridge faulty (most likely i would guess), wire off the circuit board or the phono plugs/sockets at the back loose. Check the wires on the cartridge are ok as well. Have you also swopped the outputs just to check the cable to the mixer/amp?
Hope that helps
Posted on Jul 22, 2009
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
I am looking for new covers for my 1210 mk2 turntables
Hi, we have them in stock. Styluscity@gmail.com
Mar 05, 2011 | Technics SL-1210 Turntable
I have 2 technic sl1200s and the right table has noise coming out of the speaker when i moved the tonearm. when music plays, it sounds like the treble and volume of the right speaker is weaker help...
If your left technics sounds good, maybe the problem is the cartridge. Try to interchange the cartridges, right table cartridge by the left one, and listen. If now the bad sound comes from the left table, it´s time to get a new cartridge or stylus. If the problem continues there is something else to look for. Hope this will help. Flavio/Brazil.
Sep 17, 2010 | Technics SL-1210 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
- OPTiC
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
No sound out of deck
If you've already replaced the RCA /Phono cables, then the only other item that would cause this kind of problem is your tonearm, and it will need to be replaced.
- OPTiC
DJ Turntable Repair Expert
A DJ Pro Audio Co.
Dec 05, 2008 | Technics SL-1200 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
1210 mk2 only playing through left speaker checked everything and needs new rca phono lead how easy is it to change thanks
If you have done some soldiering and have a steady hand, it's not difficult. If you are not sure, you could destroy that little circuit board that the lead runs to, and technics had discontinued production of that part. I'd say get it done by a pro with experience.
These guys are top notch:
http://www.repairnyc.com/
Hope this helps.
Jan 13, 2008 | Technics SL-1210 Turntable
 Grubhead
Grubhead
