Question about HP Photosmart C6180 All-In-One InkJet Printer
My HP Photosmart c6150 keeps shutting it's self off and then on. Then there was a message that said pump failed
    Sergeant:
  • 400 Answers
Check the INK nozzels to see if they are clogged, Use a q-tip /or several to remove the ink in the nozzels, then check the ink jets where the ink makes contact with the paper, and clear them, if the printer hasnt been used in a while the nozzel could be clogged , with dry ink , not allowing the ink to flow. and causing the Pump fail to come on.
Posted on Jul 22, 2009
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP PHotosmart c6150 keeps shutting on and off repeating the same meassage improper shutdown.
You need to reset the printer. I had the same exact problem with a C6150. Unplug the power cord from back "while printer power is on" (doesn't have to be fully booted just turning on). Wait 20 seconds, hold # and 6 keys together and plug power back in. Continue to hold until power goes off or semi-reset message comes up. Power up (if off) press OK for any error messages and let the printer cycle. Should be good to go. Mine sounded very noisy while it was trying to allign internally. I can only suspect that was the initial problem but this process fixed mine and it runs great now. Hope this helps.
Jan 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a c6150 all in one hp with a oxc 18a0206 error code how do I fix
goes through below link i think it will help you
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Photosmart-C5180/m-p/130071/message-uid/130071
Dec 08, 2009 | HP Photosmart 3310 Printer
My HP PhotoSmart C6150 printer keeps restarting.
I had this same problem with my C6180. Printer was well out of warranty so I removed the three black torx screws holding cover over mother board. I then removed screws holding mother board to chassis and found a 330 uf 10V capicator that was swelling. I replaced the capicator at a cost of $1.70 and everything works fine now. Better than buying a new printer.
Oct 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C6150 shows an "Out of Paper" message. I have repeatedly removed paper and added it back, message still shows & it won't print
Dear sir your printer problem is paper sensor when you stay paper then paper switch is open but this printer paper switch lever is broken or displace please chack it then solve your problem
Jul 20, 2009 | HP Photosmart C6180 All-In-One InkJet...
Same problem, hp c6150 turns on and shuts down in infinite loop.
In visiting with HP Support Personnel, this issue is most likely caused by a faulty power source. I have the same issue with our C6150 and they recommended that I look at replacing power cable. I am currently trying to find a new power cable.
Jun 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6150 Printer that turns off then back on repeatedly
Please DON'T keep posting messages that say "I had the same problem..." Those are useless!
If the software resets don't work, it's possible it's an electronics problem. Here is a repair note that worked for me:
http://www.fixya.com/support/t5821942-hp_photosmart_c6180_continually_powers
Jun 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Installed new computer - keep getting error - HP Photosmart C6150
Try
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
378 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
