Question about Singer Inspiration 4210 Mechanical Sewing Machine
The belt is not moving when i pres the pedlle
It seems that the belt is fine but i don't know why is not moving the needle and the belt,even sometimes it moves the belt the bar for the needle won't move. Thank you ... help
  • 55 Answers
It sounds like your machine may be seizing up. it needs a service. oil all moving parts with good sewing machine oil (not 3-in-1 oil) and work the oil n b turning handwheel by hand for a while.
if this does not free-up machine have it serviced by a tech.
scott
Posted on Jul 27, 2009
Kenmore sewing machine motor running belts moving but needle not going up and down
Is there a clutch that allows you to move the fabric through without the needle stitching (usually a knob in the centre of the wheel. That could be loose or worn.
Jul 18, 2017 | Kenmore Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Singer 404 - The top needle thread will not pick up the bobbin thread on a Singer 404. I know the timing is fine, the needle is in correctly and I have loaded the bobbin thread correctly. I don't know...
is it the original bobbin? try a different bobbin, sometimes they won't work if slightly dent or chip! I know it sounds weird bt it's the truth about bobbins
Nov 14, 2013 | Sewing Machines
Singer 9030 runs but don't sew
try changing the needle--make sure the needle is the correct one
for the fabric being sewed.
also make sure the needle is turned the correct way in the needle
holder and pushed all the way up into the needle holder.
Nov 08, 2012 | Singer Sewing Machines
Nothing works,but engine and belt run
the machine probably needs to be check to see why the needle & bobbin aren't working
May 28, 2012 | Singer 1507
Needle seems to be hitting something down inside causing it to bend/break
I would say we need more info about the problem, like make, model, etc, etc., but, the truth is regardless of what brand it is, if the needle hits anything during it's journey down into the bobbin case area, then it's simply out of time. This is usually the result of someone trying to clean or repair the machine when they don't know what they're doing. Somehow the belt has slipped. If it's a geared drive belt then you must release tension, move it a tooth one way or the other and put it back together and try it, easily, to see if it's better. IF not then try it another tooth and so on until you get it back to where it should be. That's usually not more than a couple of teeth one way or the other. If it's just a smooth belt, then just release the tension and move the mechanism by hand in the same manner as you did with the toothed unit.
Apr 22, 2011 | Kenmore Sewing Machines
Brother CS6000i - Needle breaking, bobbin thread not picking up
There are a few possible causes, firstly make sure you have the correct needle and it is in the correct way and make sure when you fit the needle it is pusshed all the way up into the needle holder. If the shuttle or hook is moving around the bobbin case then the timing may have been knocked out. If the it is not moving it means either the gear or belt that drives the hoo / shuttle has been damaged or broken.
Jun 14, 2009 | Brother CS6000i Computerized Sewing...
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
1968 kenmore sewing machine
belts and oil it in any point that has metal to metal
Oct 02, 2017 | Sewing Machines
Singer Inspiration 4210 Mechanical Sewing Machine Logo
170 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
