Question about Refrigerators
GE Monogram won't start after the maid has cleaned it (no lights and the fridge is warm)
The wall between the freezer & refrigerator is very hot to touch, Why?
Posted on Aug 13, 2009
  • 11,896 Answers
Could either be bad compressor, power supply or relay.
I first would check relay with ohmmeter/multi-tester.
then I would check power to and from compressor with a voltmeter/multi-tester
And then do the same with power supply
Posted on Jul 21, 2009
My GE Monogram Frig door will not stay shut, it's lost its vacuum seal!
Check the fridge for out of level. Magnets on the weather-stripping hold the door closed. If there is something stuck on the seal, or too much weight in the door in an un-level fridge it will not make good contact. Try cleaning the rubber, and removing everything from the door after leveling. A good seal will stay closed even if the fridge is off.
Feb 23, 2015 | GE Monogram ZISS480DRSS Stainless Steel
Temperature is rising in both freezer and fridge. top shelf in fridge is much warmer than bottom shelf in fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | GE Monogram Side by Side Refrigerator
I have a ge monogram fridge 48
heatman101
Apr 28, 2011 | GE Refrigerators
GE MONOGRAM FRIDGE. FRIDGE TOP FREEZER BOTTOM. COMPRESSOR IS HOT, EXTERIOR BETWEEN FRIDGE AND FREEZER IS HOT. WHAT'S WRONG?
nead to know more, the area between the frig and freezer has a heater in it to prevent moister buildup.you can turn this off by turning on the energe saver mode.next you nead to take the kick plate off in the frount and bottom off frig.on the right you should see the condencer coil's, clean them.
Nov 22, 2009 | GE Monogram ZDI15C Automatic Icemaker
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Jun 06, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
How often are you supposed to change the filter? (GE Monogram)
GE recommends once a year for the water filter for light use and twice a year if used heavily.
Please take time to rate this fixya.
May 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
