Question about Brother HL 1240 Printer
The alarm is flashing. Checked everything nothing
The alarm is flashing. Checked everything nothing seems to be wrong I even changed the toner
  • cruttka Jul 21, 2009
    The alarm light is on and the drum light is flashing
    President:
  • 2,777 Answers
Hello there, first thing you will want to do is shut off the printer with the power button. Then go ahead and unplug it from the power source (wall or power strip). If it doesn't let you shut it down with the power button then just unplug it.
Give it a good 2 minutes and plug it back in. If the alarm is still going let me know. Does it have any error message on the screen of the printer?
Just to confirm, this is a model HL 1240?
Thanks
Tim
Posted on Jul 21, 2009
  • Tim Grayson
    Tim Grayson Jul 21, 2009
    Ok, so unplugging it for a while did not take care of the issue? Is it a brother BL 1240 then?
    Thanks
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
HP LaserJet 4250n Printer all pages blank even with new toner
Have a service tech check for the presence of the hi voltage applied to the paper to attract the toner.
Mar 10, 2017 | HP LaserJet 4250n Printer
My Samsung CLP 300 shows a red light. I've cleaned the toner tub and checked for paper jams, but still no results. How do you use the laser printer to check what's wrong? Any...
The red light stays on even in cases there's a paper size mismatch, and press the GO/START button usually helps. Also, it may be an indication that one of the toners is empty. See the level of the toner, the printer control program does this. If nothing seems to be wrong but you still have the red light on, unplug the power cord and plug it back in after a minute. Hopefully that may help.
Jan 18, 2011 | Samsung CLP 300 Laser Printer
Paper keeps jamming. It seems to get halfway through the toner and then the jam alarms go off.
Poor line condition. Everything is plugged in fine. Could my settings be wrong?
Mar 12, 2010 | Brother IntelliFAX 4100 Laser Fax
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Clicking Noise Coming From Under The Hood
Have you checked your belts? A piece of belt may have come off and been slapping under your hood, and then fell off completely. While it was slapping, your computer would have detected the slow down of pulleys etc. and caused your engine light to come on. Then when the piece broke off, everything would be back to normal. Let me know!
Apr 08, 2009 | 1998 Lincoln Town Car
Toner Missing Light Error persists
use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridge.
Feb 03, 2009 | HP LaserJet 1320 Printer
Help! my car is possessed
i may be wrong at this but i think it's your alarm system. headlights, doors and horn all connects to an alarm system (if your alarm system does this) i mean, some alarms, when you unlock or lock your car, the lights turn and horn blows simultaneously with the alarm. if you have an alarm system that seem to malfunction, it may also affect your doors, horn lights etc. have it checked or replaced.
well, as ive said, i may be wrong. =)
Jul 15, 2008 | 1997 Honda Civic
Samsung ML-2510 Red light on & won't print.
This may be a help. I had a similar problem with an ML-2850 which fresh out of the box refused to print, not even a test page, green light followed by red and the smart panel showed that the printer thought that there was no toner in it.
After struggling with it for an hour I hit upon the following.
Turn off the printer.
Take out the toner cartridge.
In the hole where the toner came from there's a gear on the left hand side which is sort of diagonal mesh to match the underside of the toner cartridge. Rock it back and forth a bit and then stick the cartridge back in.
My guess is, if you're unlucky when you install a new cartridge you could have a situation where the gear is in exactly the wrong position, tooth to tooth with the underside of the toner so this gear doesn't mesh properly, the cartridge doesn't seat properly, which then shows the printer as having no toner in it. Waggling the gear just changes the position slightly and then voila. A bit like rocking a car back and forth in gear to free a stuck starter motor.
Mar 28, 2008 | Samsung ML-2510 Laser Printer
Brother HL 1240 Printer Logo
49 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
