Question about Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w
Brother printer machine DCP-J140W to Ink box full error
SOURCE:
SOURCE: Brother DCP 110C printer error
thats what I find useing the search button here:
http://www.fixya.com/support/t265668-not_printing
Posted on Feb 20, 2008
xptareq2000
  • 1447 Answers
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Posted on Nov 22, 2009
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
  • 8 Answers
SOURCE: Brother DCP-195C Compact Colour Inkjet ... i have
Brother DCP-195C Compact Colour Inkjet error unable clean 46
Posted on Sep 07, 2010
  • 525 Answers
SOURCE: where do I get an ink absorber box for my brother
There is no reason to clean or replace. Just reset counter with this procedure.
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Feb 02, 2011
My brother printer j140w problem massage coming on screen "ink box full"
It may refer to the ink "overflow" box. When your printer cycles, it will dump a bit of ink which goes into a collection box. Most likely, that box is full and needs to be emptied, replaced, or whatever.
Dec 24, 2016 | Brother DCP-J140W
I have a problem with "brother DCP-J140W" printer, it shown at the LCD "Init unable 4F" i was thinking the problem must be the printer head, can it be repaired or just replace the head ?
Hi
Error 4F means your printhead is RIP, mostly due to bad quality ink, the only one way to fx the printer is changing the printhead but... is that really worth it?
Well, check on ebay.com or isscx.com if you can find your part at a good price!
Best Regards
Jul 22, 2016 | Brother Dcp J140w - Multifunct
Ink box near full
heres the solution for ink box near full
1 power on the printer
2.press menu, mono, menu
3 press arrow up or arrow down look number 8 then press ok
4.press arrow up or arrow down look number 0 then press ok
5.press arrow up or arrow down PURGE Counter then press 2783
6.press 99 to exit maintenance mode or unplug the machine
7.turn back on the printer
Jun 23, 2015 | Brother DCP-J140w Wireless Compact Inkjet...
How to fix brother dcp J140 message unable to init 4f?
Error 4f means that your carete is damaged, probable after using not oryginal cartridges, it's reportable but to expensive. If you used brother ink, you can do an complaint I in brother service point.
Feb 16, 2015 | Brother DCP-J140W
I have a brother J140 W i followed your instructions to clear purge full ink box and it worked,I thought great,But now when i print the black ink goes into the yellow when I do a test I have 2 black i cyan...
Did you actually change any parts or just reset a warning? If you were getting a full error, chances are the purge system was full and needs to be changed. Likely what the problem you are having is that ink from the purge system is backing up and polluting your print heads.
Jan 04, 2015 | Brother DCP-J140w Wireless Compact Inkjet...
How to solve the problem of see troubleshooting and routine maintence chapter in users guide in .it unable 4f in dcp-j140w wifi brother printer
A print unable message in a Brother inkjet usually means the waste ink chamber is full. This can be fixed by removing the waste bottle, cleaning and drying the pads inside, then reassembling the machine and resetting the purge counter. Most of the instructions for this can be found on u-tube. Please note it is a messy job and many folk just replace the machine.
Dec 03, 2014 | Brother DCP-J140W
My brother DCP-J140W printer ink box full .. please help how to fix it.
The Brother manual says that you are required to replace the ink absorber box at a Brother Service Center. This is not an item covered by warranty.
http://www.manualslib.com/manual/437931/Brother-Dcp-J140w.html?page=44
Sep 09, 2014 | Brother DCP-J140w Wireless Compact Inkjet...
Hello, I have a Brother DCP-J140W printer and the
You can still print in black using the 3 colors. See the printer configuration. After a while it will clear up.
Sep 28, 2013 | Brother DCP-J140W
Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w Logo
345 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
