Question about Battery Technology Computers & Internet
B&Q Electronic Safe For Laptop Anthracite
Does anyone know how to reset this safe? I have access to it by key, but do not wish to use the key I want to continue using the electronic keypad!
I opened the safe to change the batteries, and then closed the safe. I entered my code and the display showed 'error'. I presume that because I changed the batteries that I now need to reset the code.
Please help, Ican't find the operating manual - this is the first time I have had to change the batteries in two years and I am really frustrated.
Anyhelp will be appriciated.
Thanx
mumma_1
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: PCG-F540 service manual
No hay problema, yo hablo tambien castellano, perdona las falta de ortografia.
El manual de servicio no lo tengo, pero te puedo decir que hay dos maneras de aceder al disco duro del Vaio, dependendo del modelo.
En algunos tiene que remover la tapa que se encuentra a la base del portatil, esta suele ser marcada HD, y se encuentra cerca de la tapa de la memoria RAM. Este deveria de ser su caso.
Aqui esta el diagrama de su ordenadora.
El HD es la pieza 24, y se inesta en el HD Slot, indicado con G:
Posted on Oct 19, 2008
  • 7 Answers
SOURCE: no operating system found
Sounds like you have some settings in your bios messed up, when your computer boots up either press F2 OR DELETE AND ENTER BIOS go to where the password settings is and uncheck that also you may have deleted your operating system by mistake, you may have to reformate your partion and redo your current windows. Hope that helps.
Posted on Sep 11, 2009
SOURCE: need to reset electronic safe
i have changed batteries and pressed the reset button but it still wont open any ideas thanks karen
Posted on May 29, 2010
domotek
  • 591 Answers
SOURCE: blue error screen, cannot access the main page
OK this one is probably a newly installed driver or software, so when in safe mode remove the last software you installed or driver then reboot it wil probably be OK if NOT... check for viruses (BTW if you want to have access to the internet when in SAFE MODE) choose SAFE MODE WITH NETWORK CONECTIVITY then you can UPDATE the antivirus than scan the computer
GOOD LUCK!
Posted on Jan 14, 2011
I need to open the safe and the batteries are dead
Hello there,
You SHOULD have a mechanical key to open it in case of emergencies like this..
If you purchased it, you will have the key friend.
Extract from this page.http://www.officespecialties.com/fireking_lt1507_personal_laptop_safe_182604_prd1.htm
'The electronic lock provides security and easy access and it is equipped with a mechanical key for emergency access. The door is 9 Gage and the body is 14 Gage steel to resist break-ins.'
If it is lost, you need a locksmith.
Sep 24, 2014 | Safe International Gary LT1507: Laptop...
We don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Jul 14, 2014 | Safe International Digital Electronic Safe...
Where can i get a replacment key for nutool sf20 safe have number
I have lost my dads keys for his NUTOOL SF20 Electronic Digital Safe. How can i access it and where can i get a new key from?
Apr 29, 2010 | Safe International Digital Electronic Safe...
Have a SURESAFE brand safe at work which have no instructions
Hi there all I have a SURESAFE electronic security safe MODEL-OWSAFE30ES
(1) To set your own code first on safe
(2) locate the red reset button on the hinge end of the door.
(3) Press the red button, which will illuminate the yellow light on the keypad.
(4) Now key in your new code (3 to 8 digits) and press A or B to end. Note you have 30 second to complete this step.
(5) Test your new code whilst the door is open. Safe will beep twice to confirm code has been entered correctly, and knob can be turned clockwise.
(6) Repeat process any time you wish to change your code.,
Hope this help
regards
rick
Dec 30, 2009 | Safe International Digital Electronic Safe...
Need to reset electronic safe
Jul 22, 2009 | Kitchen Appliances - Others
Kingavon safe 28 door locked open, how do i reset code?
electronics not working can t find key need one but don t have any addresses or telephone numbers can anyone help
Jul 17, 2009 | Safe International Digital Electronic Safe...
SD102 missing the key
Hi.
Yes, you need the key to open it.
Your code is 4 numbers (one or two digits each).
First turn the knob several times counter clockwise To "reset for starting)
Turn the knob clockwise. Stop when you hit the first number the fourth time. Then counterclockwise, and stop when hitting the second number the third time. Counterclockwise again until you hit the third number the second time. Counterclockwise, and stop when hitting the fourth number the first time.
Now you need the key. The safe opens when you turn the key clockwise. I don't know where to order a new key, but I suppose the manufacturer can help. Your key number should be engraved ON the lock. Mine has four digits lock/ key- number.
I have not been able to find the manufacturers web page...
I wish you luck!
Stein/ Norway
Jul 08, 2009 | Safe International Digital Electronic Safe...
Computers & Internet Logo
203 people viewed this question
Top Battery Technology Computers & Internet Experts
Alun Cox
Computer Links
Terry Schallert
Are you a Battery Technology Computer and Internet Expert? Answer questions, earn points and help others
