Hi G-DyBiec
If the video capture automatically
stops capturing at approximately 18
minutes (17
minutes
and 55 seconds), then most likely the drive that is being capture to,
is formated using Microsoft's FAT32 file system. Microsoft's FAT32 file
system has a maxium file size of 4 GigaBytes (4 GB), which equates to a
DV video clip of nearly 18
minutes. (18
minutes
= 1080 seconds, @ a data rate of 3.6 MB/sec is approximately 4GB). So
for hard drives that are formatted using FAT32, this behavior is
normal. This is not a limitation of Studio..
To see what file system your hard drive uses do the following:
1. Right click on the Start button and choose Explore
2. Under My Computer, locate and highlight the drive you are capturing to
3. Right click and select Properites
4. On the General tab, towards the top, it will say "File System". It will be listed as either FAT32 or NTFS.
There are a few solutions if your drives are formatted using FAT32:
- Convert your FAT32 hard drive to NTFS *
- If you can copy any important
data from this drive to other drives, it may be faster to re-format the
FAT32 drive using the NTFS file system. **
- You can do multiple 18 minute captures and string them together in the Edit mode of Studio.
- Since the first 18 minutes is already captured, rewind the camcorder or VCR to 5 - 10 seconds before the initial capture stopped (which can be edited out later in Studio).
- Start a new capture to a new file name.
- Repeat this process until all the desired video is captured from the tape.
- After all the files have been
captured, go to Edit and assemble the captured files from the Album to
the timeline in the order you desire.
This is a manual method to
workaround Microsoft's FAT32 file system and if this is too time
intensive for your needs, then steps 1 and 2 above may be more suitable
and should be considered.
* Note: If you need assistance
with step 1 above, go to the Microsoft web site at
http://www.microsoft.com/ and search on "convert FAT32 to NTFS".
** Note: If you need assistance
with step 2 above, go to the Microsoft web site at
http://www.microsoft.com/ and search on "how to format a drive in XP".
NOTE: Microsoft's NTFS file system is only supported on Windows
2000, Windows XP and Windows Vista. NTFS support a file size of 4 TB
(terra bytes), which is larger than any current consumer hard drive
capacity, so if NTFS is used, the capture file size will only be
limited by the size of the hard drive.
