Question about Yahoo Messenger
Error 81003004..on yahoo messenger when i try to log in
  • 315 Answers
Hiya,
I'm not usually one to post links to other sites but here is a page that may be helpful.
Yahoo connection error: 81003004
I hope that helps.
Mike
Posted on Jul 21, 2009
SOURCE: login error 81003004 from Yahoo Messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Posted on Jan 07, 2009
SOURCE: Problem signing into Yahoo Messenger.
Well, I was having the same problem and I did this.
Close out yahoo
right click on the yahoo symbol thing
then select run as administrator
sign in and it should go through...
it did for me anyway and I couldn't get on for 2 hours.
Posted on Apr 01, 2009
SOURCE: Error 81003004
Go to this web page link and follow the directions
http://www.error-repair-tools.com/ppc/error.php?t=81003004&gclid=CJDm_aKP4pkCFQw9GgodVFiLVw
Posted on Apr 08, 2009
  • 79 Answers
SOURCE: Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Posted on Jun 08, 2009
yboyandrei
  • 828 Answers
SOURCE: when logging in to yahoo messenger it always says network problem
to find out what network connection are YM can get in. Go to your preferences then check your network connection.
There is 3 connection in there:
  1. DIAL-UP
  2. LAN
  3. BROADBAND
If you have this type of connection, select it.
Then you can enter you yahoo back to normal. Good luck!
Posted on Jul 29, 2009
I cannot sign in my Yahoo Messenger it always says log in error 81003004. What to do?
if this just started, it is more likely a yahoo server error. try to clear the temp internet file, cookies (browsing history) and make sure the date and time settings of your computer is correct, then restart your browser and try yahoo mail again
Nov 24, 2009 | Yahoo Messenger
Yahoo error 81003004
sometime yahoo has a glitch or two from time to time
Jul 31, 2009 | Yahoo Messenger
My yahoo msgr shows error 81003004
error 81003004
what I do ??
Jul 27, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Thanks!
Jul 17, 2009 | Yahoo Messenger
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 10, 2009 | Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
I cannot sign into yahoo messenger
The problem I have with not being able to sign into yahoo messenger is that I get an error message with number that are 81003004. It says try again...new user and sign in problems. This has been going on for many months now and I have removed yahoo from add and remove and downloaded yahoo messenger many many times. I really like yahoo and essepically my radio station I created and miss some of my friends I cannot contact any more. Please help me resolve this problem. I can sign into my home page with correct password with no problem but not yahoo messenger. Like I said the error message I get is 81003004 that is showing up on my yahoo messenger IM log in. Thank You for your assistance. chickiechackey@yahoo.com
Mar 12, 2009 | Computers & Internet
Solve error 81003004 yahoo,messanger?
what is it problem number 81003004 plz.myfamily are wait
Jan 12, 2009 | Yahoo Messenger
81003004
Go open Internet Explorer and go in the File menu and uncheck at the bottom the Work Offline option. Then go to a site using IE. Close IE. Open Yahoo Messenger and log in.
Nov 13, 2008 | Yahoo Messenger
Yahoo Messenger Logo
322 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
