Question about Samsung SyncMaster 172B (Silver) 17 inch LCD Monitor
No picture viewing on my SycnMaster 172B at all. HELP !
Dear all experts,
I have a really strange problem with my LCD monitor. I'd appreciate if someone help me, cause I'm in a big trouble.
OK the problem is kind of complicated, so I've bought "Samsung SyncMaster 172B 17" for a long time ago (about 4 years). It was working fine until a couple months ago it starts to lost the whole picture at one time with making a strange lines and it look like a galaxy or something. So, I noticed if i leave it on for a couple hours it will be fixed by itself. BUT later the problem became worst than that and could not be fixed by itself at all.
So, please please dear all experts I really NEED your half as soon as possible. And the worst part is that I cant find it nowadays in all markets.
Thanks in advance,
SOURCE: No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
Posted on Oct 22, 2008
SOURCE: Samsung screen goes black, comes back on and graphics are scrambled
check for defective and leaking electrolitic capacitors
Posted on Oct 30, 2008
SOURCE: Samsung 17" Flat Panel Monitor - Streaks
Unplug the pin connector from the back of the monitor. Re connect, tighten securly using a screw driver. Worked for me.
Posted on Feb 02, 2009
  • 18 Answers
SOURCE: Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Posted on Jul 22, 2009
  • 977 Answers
SOURCE: Samsung SyncMaster 713BM
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Posted on Mar 27, 2010
  • 1684 Answers
SOURCE: Samsung Syncmaster LCd monitor hissing standbye
The hissing sound is coming from the power supply board. It is not dangerous per say but it indicates the power supply is failing and you will begin to have more problems such as wavy picture, slow to display the picture and then finally no picture at all. We have repair guides posted on our web site at: for several Samsung monitors and a repair kit is available for this model at: You should be able to repair your monitor if you can do a little soldering. If you don't want to do the repair yourself we do offer a repair service for this model, it runs $32 plus shipping and you can get more information about this at:
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
Posted on Oct 24, 2010
Testimonial: "thanks seems alot of it on google is this brand faulty??????? would it cost alot to get repaired."
0 characters
1 Points
My problem is that with this monitor I have noticed that there is a red line that moves up and down the screen - in a random manner. I thought that the line only showed in the background but it also...
With this I would normally tell you that you have a dead pixel and you need to return the monitor to the supplier. But it is very strange that the line moves.
Dec 17, 2012 | LG 22" FLATRON LCD Monitor
My lcd tv samsung sycnmaster 940mw, after replacing all capacitors, it works for 2 months but then now im having new problem, when i switch it on, it works for awhile, then picture is disappearing (black...
Audio comes directly to multimedia LCDs and has nothing to do with display.
Usually, the capacitors are the casue of such blackouts. So, it is recommended that you check the capacitors/ other components such as invertor board and CCFL (lamp), which may be failing or heating up.
Hope it helps! Good Luck!
Apr 09, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms
One possibility is that it may have dying power supply which may be putting out unstable DC which can cause a lot of strange symptoms.
See pictures here:
Bad caps are real common problems in all brands of the monitors as you can see in my albums.
Westinghouse monitors are cheaply made to start with.
Mar 20, 2011 | Computer Monitors
Good day! The problem with my samsung lcd monitor model no. sycnmaster 540N, it takes 30mins to 1hr before displaying, but the power button blue light is blinking softly. I was able to ask this to the...
More likely to be bad caps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 12, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
I'm afraid my monitor is failing the picture
This is due to problem with the monitor circuit board. Need to repair the same with the help of local expert engineers or service center experts if you have warranty on the monitor.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Mar 03, 2010 | NEC LCD1712 17" Flat Panel LCD Monitor
try booting in safemode .. to do that.. reboot computer, as soon as it starts coming up, hit f8, then with the menu that comes up hit, start in safe mode, when windows starts up, just change refresh rate back, and then reboot normal...
Jun 21, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Jun 08, 2009 | LG L192WS LCD Monitor
Samsung ls19 blinking light no picture
well r u a electronics expert if no then just take it to a service centre coz the circuit have lil circuits that can get affected to and the major problem could be the switching transistor
Oct 22, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Strange Display Issue
Although it could be a monitor problem, try deleting it from the Device Manager list under Monitor.
Then reboot your PC and if you are lucky, Windows will find it and reinstall the necessary driver.
Considering that it is an LCD, there aren't many ways it can cause that kind of display.
Aug 26, 2008 | LG Studioworks 570LS 15.1" LCD Monitor
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
Samsung SyncMaster 172B (Silver) 17 inch LCD Monitor Logo
24 people viewed this question
Top Samsung Computer Monitors Experts
Rugeshan Lanka
Rugeshan Lanka
Level 1 Expert
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Computer Monitor Expert? Answer questions, earn points and help others
