Question about Cell Phones
Cant get mobile to do anything
I cant get my mobile to do anything it says on screen USB configure does anyone know what that means
How to edit the StartUpCtl on Motorola MC75A via SD Card
Jay
Contact Zebra Technologies or Motorola Solutions
Get Support
Mark
Motorola Mobility Support
Motorola MC75A
Jan 21, 2014 | Motorola MC75
My Hp Mini 100 keeps restarting! Same thing on safe mode and last known configuration mode! It restarts then this blue screen flashes in like a milisecond and i cant read it then it starts all over again!...
HP has an article on this .. and it says you can do it from a USB stick.
put http:// -- before this link...
h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=3832468&prodTypeId=321957&objectID=c01634414
Good Luck,
Bill.
Nov 29, 2010 | HP Mini 1000 Netbook
Epson t88iv error codes 32
Did you set it up using Epson's receipt printer drivers? If so, right click on it and choose properties. Under the PORT tab, check and make sure it is set for proper port (LPT1, COM1, USB, etc). If you make changes, click APPLY, then OK. Then Right click, PROPERTIES, Print test Page. If you can't get test page to print, your wasting your time sending codes to printer.
Let me know if you need more assistance.
Aug 31, 2009 | Epson TM-T88IV Thermal Printer -...
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Nokia 6085 has a blue screen
take the phone to a mobile service center and have the LCD replaced on the phone.
Jul 02, 2008 | Nokia 5200 Cellular Phone
Wap configuration
you should contact your mobile carrier customer service line and have them assist you with this
Jun 10, 2008 | Nokia 3110 Cellular Phone
How to Open up the N-73.
Hey dude,
I recommend u not to open ur screen urself. You may damage ur mobile if u do urself. Just go to a mobile technician.
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
May 12, 2008 | Nokia N73 Cellular Phone
Idk how to getpics on to my computer
Connect USB or a data cable that u got with ur mobile or get it from any mobile shop around u which is suited for ur mobile...
Conect one end of cable to ur phone and other end to USB PORT at the back of the PC or whereever ur USB port is located
Once u have done that, ur computer will make a sound ( DING DONG ) and u will see a screen which will ask u for an action
This is the same autorun screen that comes up when u put a CD in ur system
U can click on " OPEN AS FOLDER TO VIEW FILES " and now all the files in ur phone will be visible to u as folders and u can do normal copy and paste...
if u are not able to do anything after the phone has made DING DONG sound then goto my computer and there u might find the icon among other folders for C: and D: for a removable drive which would be for ur phone . Just double click on it and u shud be able to view files in ur phone and do normal copy and paste
Feb 19, 2008 | Samsung SYNC SGH-A707 Cellular Phone
My screen fell off hellp me
you can buy a screen off ebay and with a T6 screwdriver replace it yourself, it's really easy
May 25, 2007 | T-Mobile Sidekick II
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
