Question about CorelDRAW Graphics Suite X4 for PC (CDGSX4ENPC)
If I move or delete an object the screen does not show the change
Running XP pro latest updates Corel X4 with latest SP installed
    Scholar:
  • 71 Answers
Try resetting the workspace:
Corrupt workspaces may lead to problems with the operability of the application and in some circumstances can prevent the application from launching. To restore default settings in CorelDRAW and PHOTO-PAINT, do the following:
  1. Hold down the F8 key on the keyboard.
  2. With the F8 key depressed, launch either CorelDRAW or PHOTO-PAINT
  3. The following message will appear:
    Are you sure you want to overwrite the workspace with the factory defaults?
  4. Click Yes and release the F8 key.
Note: Some newer keyboards have an "F Lock" key that must be pressed first to activate the Function keys on the keyboard.
Posted on Apr 21, 2010
Unable to burn discs using Corel Video Studio X2. Program all OK until final phase of burning. Using Windows 7 on new PC. Could problem be Windows 7? Any help appreciated.
Make sure that you have all the patches installed from Corel's site, there is a known issue that the buttons will not show up on Windows 7 unless you have the latest patch.
If you have all the update installed there could be a few different issues.
1. update direct x from Microsoft
2. Make sure your video card drivers are up to date
3. Try rendering the project first and then burn the rendered file to the DVD
4. Try burning a Disc image, the option is on the final burn screen, if you are able to create the disc image try a different burning software that you may have installed on the system
Sep 11, 2011 | Corel Video Studio Pro X2 for PC
I been using the corel videostudio on my Gateway computer which is not a fast computer at all. so I'm trying to download it to my Dell 1720 computer which is 100 time faster then my gateway. but my...
If you still have the hard disk where that program is installed (Program Files), try to connect it as slave driver ,,, BUT (IMPORTANT) BE SURE to use the identical version of the Operating System that you are going to use (example: if it is used in a Win XP SP 2 before, then you should install Win XP SP 2 OS or as a secondary OS [if you're using Win7 now] at your Dell PC) in order to use the software again.
But if your old Hard disk was reformatted, I suggest that you should buy or download the latest version. I just visited the COREL support site and they did'nt have that X2 support anymore.
Jul 20, 2011 | Corel Video Studio Pro X2 for PC
I need the activation code for the following serial number for corel draw X4 DR14T22-FKTH7SJ-KN3CTHP-5BED2VW
corel draw x4 crack
change the date 2010 to 2009
the install the corel draw x4
download the keygen from
extract the zip file of keygen
open the 'corel draw x4 keygen' folder
open x4 keygen
in keygen press 'key code' button and copy the serial no.
then open the corel draw x4. paste the serial no. (ctrl+v).
click on the phone corel and copy the installation code and go to keygen and paste the installation code then click generate button and copy the activation code the go to corel darw and paste it the click finish
Jul 19, 2011 | CorelDRAW Graphics Suite X4 for PC...
S/No: DR14B98-NMPMSL9-MM7WT66-8D884F8-TBVHS Plz send the activation and installation code for Corel X4 Email: tejaswi_kadialas@yahoo.com
10 Simple Steps to crack corel X4.
Step 1 : change the date 2010 to 2009
Step 2 : install the corel draw x4
Step 3 : download the keygen from http://www.filestube.com/e94732d7504edf0a03e9/go.html
Step 4 : extract the zip file of keygen
Step 5 : open the 'corel draw x4 keygen' folder
Step 6 : open x4 keygen
Step 7 : in keygen press 'key code' button and copy the serial no.
Step 8 : then open the corel draw x4. paste the serial no. (ctrl+v).
Step 9 : click on the phone corel and copy the installation code and go to keygen and
Step 10 : paste the installation code then click generate button and copy the activation code the go to corel darw and paste it the click finish
IT WORKS......................
Jan 04, 2011 | CorelDRAW Graphics Suite X4 for PC...
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
I am trying to insert .jpg files into my Word Perfect Document. Certain files will not show up on the screen. The space is there in the document, the box is there in the codes, but the picture is not...
Do you know the version number of WordPerfect X4 you have installed?
What version of Windows are you using (e.g. XP, Vista or Win7)
Make sure you have the latest service pack installed:
http://www.corel.com/servlet/Satellite/ca/en/Content/1153321224268?pid=1208292570684
One issue is that the JPEG filter is not compatible with the images you are using, that is why the ones that you save in PhotoShop work, because it re-creates the images using a different JPEG filter.
the work around for that issue would be to re-save the JPEG's that are not working in PhotoShop or any other photo editing software. PaintShop Photo Pro X3 has a built in batch convert were it will allow you to save a batch of files to a different format.
Another reason and this is only if you are using XP with a P4 processor is that there is a known issue with app in WPX4 that is called CDRCONV.EXE. There is a workaround for the known issue, click on the link below for the work around:
http://corel.custhelp.com/app/answers/detail/a_id/207681/kw/207681/p/8/r_id/166
Apr 20, 2010 | Corel WordPerfect Office X4 Standard Full...
Can any on provide me a activation key for corel draw x4 ..i couldn't update the corel draw... i had downloaded from torrents if it works i will rate 4..
I too am having hard time activating my CorelDraw X4 downloaded from a torrent site.
I have to give you heads up to resolve your problem. Get the keygen from CORE for x4 SP2.
I had installed X4 on 6 PC using CORE.
Just be patient though.
Hope this helps.
Mar 23, 2010 | Corel DRAW Graphics Suite X4 for PC
Corel draw x4 activation code
Telephone COREL, and have your credit-card ready.
Any other method is "software piracy", which is *NOT* allowed on FIXYA.
Jan 29, 2010 | CorelDRAW Graphics Suite X4 for PC...
Activation code - CorelDraw X4
corel draw x4 crack
open x4 keygen
Sep 29, 2009 | CorelDRAW Graphics Suite X4 for PC...
I have an acer laptop with xp pro sp 3 installed(updated from sp1). I cannot access messenger mail and some ebay pages, error message on screen (page cannot be found).Have checked security settings against...
Acer Travelmate 4000 Series Laptop.
After upgrading Windows XP Pro to SP3 (from SP1) I encountered the problems with messenger mail and certain web pages being unable to open. I have since upgraded Java to the latest version ( not sure if this helped ) and then upgraded Internet Explorer to IE7 (was previously running IE6). Since then I have encountered no problems with messenger or any web pages. Hope this can assist any people that have similar problems.
Jul 20, 2008 | Computers & Internet
CorelDRAW Graphics Suite X4 for PC (CDGSX4ENPC) Logo
94 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
