This is a heating and cooling through the wall heat pump. It works normally when heating is selected - the heat pump runs and both speeds of the fan blow warm air. But nothing runs when cooling is selected. In other words the unit works normally when "High Heat" or "Low Heat" is selected but nothing runs when "High Cool", "Low Cool" or "Fan Only" is selected. The position of the Fan Cycle Switch has no effect - behavior of the unit is the same in both positions of the Fan Cycle Switch.
  • 614 Answers
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Posted on Jul 22, 2009
Does the engine cooling fan run continually
No the cooling fan should run continuously.
May 11, 2014 | Ford Fiesta Cars & Trucks
My remote will not change the fan speed on my mini split heat pump in the heat mode but will change speed in cooling mode. checked batteries and pressed restart button no changes
in the heat mode the fan mode run automatically first in low mode and after a while it run normally ,how you set on the remote.if you can-t set on the remote is possible to have problem to the remote.
Dec 12, 2013 | Comfort-Aire EHW 12 Air Conditioner
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
Speedometer and Odometer not working at times, matches with engine heat cycle
Your vehicle speed sensor is mounted in the transaxle housing which is also subject to heating and cooling. The wiring harness to and from the speed sensor is also subjected to engine heating and cooling. Anybody that knows anything about electrical circuits can tell you that an electrical circuit's worst enemy is heat. You need to diagnose the vehicle speed sensor circuits like the code is TELLING you to do.
Jun 02, 2012 | 1998 Ford Windstar
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
When idling my jeep overheats. The cooling fan is running and it speeds up when temperature goes up. The temperature gets close to 260 degrees and the engine tries to stall. when I start moving it cools...
At idling speed an engine does build up a lot of heat and the cooling fan will kick in. In slow moving traffic or traffic jams the temperature gauge can touch the red - particularly on hot days. The reason it cools down when you start moving is because of the air flow through the radiator.
Presumably there are no leaks from the cooling system otherwise you would have mentioned it. In normal circumstances the fan will not be running as you are driving at speed, as the air-flow through the radiator is sufficient to cool things. The fan only kicks in to get rid of excess heat - and this usually occurs at idling speed or after you have parked the car.
If the fan is running all the time as you drive, this points to either a fault in the fan switch, or the car is running too hot. presumably in normal driving the fan isn't running and the temperature gauge reads normal?
It is common - in stationary traffic many cars overheat (particularly big engined models) try to stall and 'cut out'. Restarting can be difficult until the engine cools down.
Is your car overheating in normal driving conditions or just at idle speed? Overheating in normal driving conditions can be caused by things like a failing water pump, blocked radiator, collapsed hose, faulty thermostat or, in the worst case scenario, cylinder head problems.
Overheating at idling speed is 'common'. Check your coolant level. If your car isn't using/losing coolant then there probably is no major problem. You can flush out the cooling system and refill with new coolant - and also check your radiator. Are the cooling fins crumbling with age? Or maybe they're partly clogged with insects and debris from the road? A blast with a hosepipe wil sort that out ..
The question is how much does your car overheat in normal driving? If it doesn't .. it appears as though you have nothing to worry about as such. Most cars have 2 speed fans... the 2nd faster stage kicks in at some point dependant on engine temperature. Perfectly normal.
Aug 14, 2010 | 2003 Jeep Grand Cherokee
Why is my heat/front defrost not working very well. Only shoots warm air? And not very forceful.
hi from uk can i offer this advice ? when you start engine let it warm up a little then drive untill temp guage reads warm at least ? then when you put front screen defrost on only select screen and No 2 speed then as temp reaches normal screen will clear fully if you select full speed on heat blower to clear screen at first start it will not work because the coolant from engine passing thro the heater matrix/radiator will be rapidly cooled by fan of heater TRY IT? in years gone by it was common remedy if you were stuck in traffic and temp rose towards hot you could cool system down by putting heater on full heat and the fan on max this cooled the engines coolant as it passed thro the heater ?hope you understand how heater/fan should work for optimum efficiency my wife has owned 2 of these accents and never had heat/demist problems it is surprising how many people consider the demist/heater systems are poor on many cars not just hyundai hope this helps best wishes
Dec 15, 2009 | 2001 Hyundai Accent
Hp slimline cooling fan is always running
there is not really an answer for this question.
your machine has fan o fans running all times to avoid the CPU from over heating and BURNING, you see how compact it is. consider this. how much heat will come from the CPU, hard drive, GPU, RAM sticks and cd/dvd drive, ahve them all working and not cooling system at all your pc will overheat in less than 20 minutes.
Oct 07, 2009 | Computers & Internet
Fan slows to about half speed when heat cycle kicks in
The heat fan speed is slower than the cooling speed. About 300 rpm less.
You may not have a problem.
May 20, 2009 | LG Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
