HOW DO I SCAN PICTURES TO MY MAC OSX
Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one. Make sure that the product is connected to the computer. Turn the product on. Load the picture or document: Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid. ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION:Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos. Use HP Scan to start a scan Use HP Scan to scan items and edit them to adjust resolution or color, crop, remove red eye, etc. To scan a picture or document, follow these steps: Open the HP Scan program in the Hewlett-Packard folder. From the Scan Profiles screen, click either Pictures ( ) or Documents ( ) . Click Profile Settings , and then adjust any settings in the Capture , Adjust , and Page Options (for documents) or Enhance (for pictures) tabs as appropriate. If you want to save these settings as a custom scan profile to use in the future, follow these steps: Click the drop-down list to the left of Profile Settings , and then click Duplicate Selected Profile . Type a name for the profile in the text box under the profile icon. The new profile saves under Custom Profiles. Click Scan . Make any desired changes to the scan preview by using the icons available in the toolbar and the Adjust window. NOTE: You can use + and ? buttons in the Bottom bar to add or delete pages in the OUTPUT list. You can reorder pages by dragging them to new positions in the Sidebar. Select a destination from the Toolbar: If you opened HP Scan from other software, and want to send the scan to that software, click Return . If you are ready to save, print, or send the scan to a specific destination, click Save , Print , or Send . NOTE: If you are saving the file, make sure to select the file format that you want.
I got the correct drivers and it works now. Thanks!
Clear, concise advice and my problem is now solved.
