Question about KitchenAid Ovens
F1code comes on display panel - KitchenAid Ovens
  • 6,784 Answers
This is an unfortunate Board failure code. you will need to replace the ERC or, control board in this case. it has failed.
Posted on Jul 21, 2009
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
Oven display is blank and oven light does not come on
90% of the time this will be the main control board if neither of the displays work. Here is that board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | Ovens
15 year old ge profile with f1 fault code. what is f1code.thanks
f1 is usually a control error fault usually means the control board has to be replaced in the unit this is what it says in the service manual for your error GE Gas or Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
how to distinguish between a fault with the touch pad and the control you would have to take and disconnect the power to the unit first and then unplug the touch pad from the control and then replug the unit in for 5 minutes if the error code is still there then you have a defective electronic control if it is not then you would have a defective touch pad it is very rare that you do get both that are defective all at once if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue to help others in similar situations in the future Thanks again I await if you have any further reply
Rick
May 04, 2011 | Ovens
My RBS245PD won't come on at all. The panel display is not working and the light doesn't come on either.
Have you checked the isolation switch for the oven and the breaker at your fuseboard (mains distribution panel) is on?
please vote thanks
Feb 03, 2011 | Whirlpool RBS245PD Electric Single Oven
My display panel doesn't show lights. It will beep when I touch the clock, etc., but no lights. The inside oven light will come on. How can this be fixed?
This is a failure in the control board. It can be rebuilt by fixyourboard.com to save money vs. buying a new one. It is often an intermittent problem and sometimes accompanied by a random E6 F2 error when (or if) the display comes back on.
Aug 15, 2010 | Whirlpool RBD275PD Electric Double Oven
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
May 15, 2008 | Whirlpool RBD275PD Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Ovens Logo
57 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
